Old 04-19-2012, 07:25 PM
SUT-UP SUT-UP is offline
SUT-UP is on a distinguished road
Default Re: Another LineX Interior
Bringing this thread back.
Yepp and Guru What's going on?
Yepp, What PA did you use and how does it look from the dash side?
Guru, Did you just make a blank for where the onstar buttons were or did you leave your onstar in?
I want to do a combo CB/PA in the spot where the Onstar is located. Read the install about the Redneck Onstar on the other forums. That looked good but all the smaller CB's are without a PA system. I found one cobra that may work. Wanted to get your inputs. I wish that Cobra 75 remote CB came with a PA function. It would make it the perfect install for right there. I mostly want the PA but can't justify not having a CB also.
What you guys got going on for opinions?
Thanks in advance.
Old 04-19-2012, 07:35 PM
guruerror's Avatar
I fabbed a blank for my OnStar spot out of plexiglass and fiberglass resin then sprayed it with some bedliner to match the rest of the dash.
I agree...I wish my Cobra had the PA. I'm actually getting ready to yank the CB and install a PA. I never use the CB except to listen and it makes more sense to use the Bearcat for that.
CNTRY
DTOM
Old 04-19-2012, 07:38 PM
What are you going to use for a PA? Any Ideas?
Old 04-19-2012, 07:40 PM
guruerror's Avatar
LOL! I was just ready to ask you for ideas...check this one out: http://www.amazon.com/Assured-Perfor...4860691&sr=8-2
I'm not too sure about the brand, but it gets some good marks. I'd rather have something that was labeled 'rugged' or 'water resistant' though.
CNTRY
DTOM
Old 04-19-2012, 07:49 PM
I was thinking about going with the Whelen product. It is definitely going to be a costlier route, but my buddies wrangler has the Cobra CB w/ PA system and its way too quite for me. Plus always have to 1-up the wrangler.
http://www.whelen.com/_AUTOMOTIVE/de...68&prod_id=187
Its got a good detail about it:
http://www.whelen.com/install/133/13327.pdf
Seems like it may be a way to go and then just install the Onstar CB without a Pa like HumminNBoatin did. I wont use the CB other than listening except when on a trail or roadtrips. So I can just leave the CB microphone detached and have the Whelen attached and visible. Or the entire Whelen system in the center console and the CB microphone exposed
Old 04-19-2012, 07:58 PM
guruerror's Avatar
Check out Carson too...http://www.thepublicsafetystore.com/sirens.html
I've got the HA-150 stutter horn and it's a real attention getter. LOL! I think I'm lean toward the SA-385, mainly because I've already got the Carson speaker installed.
CNTRY
DTOM
Old 05-05-2012, 05:33 PM
SummitUp's Avatar
SummitUp SummitUp is offline
SummitUp is on a distinguished road
Default Re: PA (Public Address) installation
Using a Cobra CB/PA combo... PA is plenty loud enough for me.
'05 H2 Lux, 37" KM2's on 17" Hutchinson Double Beadlocks, Cognito UCA's, Cognito Sway Bar Links, Custom Hydro-Assist Steering Upgrade, Eaton Front Differential Locker, 1" Rear Coil Spacers, Chevy Green Key Torsion Bar "Lift," Bilstein Shocks, Warn 9.5ti Multimount Winch, Dual Optima Yellow Top Battery's, Piaa & Hella Off-road lights, Gobi Rack, Tru-cool External Transmission Oil Cooler, Diablo Predator Hi-Octane Tune.
Old 10-01-2012, 07:13 PM
Contract_Pilot Contract_Pilot is offline
Contract_Pilot is on a distinguished road
My Scanner Install..
