Old 06-04-2012, 05:15 PM
pwrhse2k's Avatar
pwrhse2k pwrhse2k is offline
pwrhse2k is on a distinguished road
Default 37" Tires
Need a little help...Will 37" tires rub with a 3" key lift and 20x12 -44 offset wheels? Thanks in advance...
Reggie
Old 06-04-2012, 07:16 PM
SUT-UP SUT-UP is offline
SUT-UP is on a distinguished road
Default Re: 37" Tires
Highly unlikely to rub with the 3" key lift. All stances are different on the trucks but I am running 37x12.5x20 with 0 offset and no keys that don't rub.
Old 06-04-2012, 08:04 PM
Stellar Stellar is offline
Stellar is off the scale
You should be fine. For clearance peace of mind you could snag green keys for cheap, and if you have coils utilize a 1" to 2" spacer in the rear and call it a day. I run 36.8x13.50 Iroks on stock rims with this set up. Great clearance with a low center of gravity is a good combo IMO.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
Old 06-04-2012, 08:32 PM
pwrhse2k's Avatar
Appreciate it gents!
I've got GM green keys and beefed up the front suspension with Cognito goodies and Rare Parts Xtreme Duty Tie Rods. Fuel Octanes and Toyo MT are going to be installed. Should look good with the 37s.
Reggie
Old 06-04-2012, 09:10 PM
guruerror's Avatar
Reggie:
It looks like the backspacing on the Octanes is 4.75 so you should be good...no rub. I ran 37"s on the stock rims (5.5 backspace) with just the keys and your Cognito gear for a while and only had a bit of rub; since I moved to the Rockstars (also 4.75 backspace) I haven't had a single rub...of course my BFG MTs (37x12.50x18) might be a bit skinnier than your Toyos
Brent
CNTRY
DTOM
Old 06-05-2012, 01:19 AM
pwrhse2k's Avatar
Thanks for the additional confirmation Brent. Unfortunately the Octanes are on back order for 30-60 days. Booooo
Reggie
