Old 06-16-2012, 04:29 AM
pdxrealtor's Avatar
Default 50k Service/Trans service
I'm at 50k.
This is what I've done or plan on doing. Am I missing anything or is anything overkill?
Tranny service.. I'm assuming I should have the system flushed by a shop... correct?
External Tranny oil cooler
Transfer case drain/refill
Front/Rear Diff drain/refill
Power steering flush -might just suck the old out and dump in some new.. opinions?
Cooling system flush
Air filter
Shocks
Steering stabilizer
Have shop inspect front steering components
I had an alignment at 27k. Do I really need another? Can tire be assessed to determine?
I'm doing my regular things... oil/filter, MAF cleaning/Tbody cleaning, lube front end, rotate tires.
2006 HUMMER H2
MOOG Front End
Diablo InTune w/DiabLew Tune
Cognito Steering Support
OBX LT Headers
Air Raid Filter w/Tube
Corvette Servo
Rancho Steering Stabilizer
Viper Smart Start
iPod/Video Interface
HID Head and Fog Lights
Old 06-16-2012, 12:30 PM
HummerMann's Avatar
Default Re: 50k Service/Trans service
I had my 50k service done at a Hummer dealership several years ago. They recommended the GM anti-foaming additive for the transmission with the fluid change because I did some towing in those days. I flush and change my own radiator fluid every three years. My front end goes out of alignment often and the old lift kit I had on it before I went back to stock, so I have that done yearly. I also put new brake fluid in at 100k. I also had to replace the MAFs and O2 sensors at 92k to pass emission testing.
Hummer, like nothing else
Old 06-16-2012, 05:21 PM
tiny2012's Avatar
tiny2012 tiny2012 is offline
tiny2012 is on a distinguished road
if you search transmission service,theres alot of info already available.
Old 06-16-2012, 05:25 PM
pdxrealtor's Avatar
One would think,, Huh?
Not many results for transmission service or any variable.
Thanks Hummerman... for your info. I might end up having to go the dealership for my trans flush.
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-16-2012, 06:16 PM
pdxrealtor's Avatar
Just bought the external trans oil cooler.
I'm thinking it would be best to install that before the trans flush. Anyone have a different opinion?
2006 HUMMER H2
MOOG Front End
OBX LT Headers
Corvette Servo
Viper Smart Start
Old 06-18-2012, 03:56 AM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
Definately switch to Dexron VI for the tranny & T-Case. It already has the newer anti-foaming spec, more shear stable, high temp stable, lower pour point, and the friction properties are MUCH better. My truck shifts like butter and the switch.
