Old 06-23-2012, 12:58 PM
citiboy's Avatar
citiboy citiboy is offline
citiboy is on a distinguished road
Talking 2008 H2 on 38" Open Country MT with Rockstar
Hey guys, just want to share some stuff that i did to my truck....still to do some fine tuning to get rid of a slight rubbing on the frame while on full turn
Stock 35"
38" tires installed
Tires, rims and wide off-road fender flares installed. Cranked the TB 1.5", i will replaced them with the GM green keys to get the full 2" lift and install 1.5" rear spacer. Rides a little noiser compare to the stock BFG's but hey, not bad for MT tires. Ordered the front Cognito UCA, steering support bracket and 4 longer Bilstein shocks.
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
Old 06-24-2012, 03:10 PM
jsbihn jsbihn is offline
Moderator
Default Re: 2008 H2 on 38" Open Country MT with Rockstar
wow thaat exactly the look i would like for my truck.
at least for now
(well and minus the rockstars)
where did you get the fender flares and does your truck sit level?
Do you have air ride still in the back?
Oh btw, what is your ground to top of roof rack measurement?
I hope to hear good numbers since i actually have a clearance issue I will have to deal with
it is nice to have someone already doing this so I could find out and not end up making a very bad and costly mistake
Thanks for the info
Old 06-24-2012, 08:43 PM
citiboy's Avatar
at least for now
Thanks for the info
I got the fender flares from Hummer Parts Club, i found that they have the lowest price. My truck sits pretty much level...i took the measurements from the ground to the lower lip of the fender flares....front: 43.5" rear: 44". I just installed 1.5" rear coil spring spacer. No air suspension. Planning to install gm green keys in few days.
Ok, it measured 7'1" from the ground to the top of the rear crossbars since the rear of my truck sits 1/2" higher than the front.
Hope this helps!
Old 06-24-2012, 09:57 PM
charles06's Avatar
charles06 charles06 is offline
charles06 is on a distinguished road
When you measure the height of your truck, use that crease that runs down the doors for your measurements...each end of the crease. I realize the crease is not toward the ends of the vehicle, but the fenders are cut differently front to rear. They are not the same height from the ground, even if your truck was sitting on its frame with no wheels, tires, suspension, etc.
Truck looks great, btw!
Old 06-25-2012, 02:20 PM
guruerror's Avatar
LOOKS GREAT! And that is a MONSTER winch...at first I thought you had a mini fridge attached to the front. LOL!
I always measure to the rock rails to determine if it's level...I guess it's six in one, half a dozen in the other...
CNTRY
DTOM
Old 06-26-2012, 12:32 AM
H2Much's Avatar
H2Much H2Much is offline
H2Much is on a distinguished road
I know this is a dumb question as I have read it several times before, but
- What is the part number for the green keys
- Can you install them on something that is already lifted, is it hard to do?
I ask because I have been needing just the slightest lift in the front and I keep reading about the green keys. I am assuming that they are the keys that you torque up on the torsion suspension in the front, am I right?
Anyway, if someone can shoot me part numbers in a PM and let me know if you have any pics or how hard it is to change them out, I would like to do this too.
Thanks in advance for the info which I am sure has been mentioned in this forum a million times already, lol.
Sweet looking H2 with not enough mods (2003 Pewter H2, 20" Rockstars, 40"x15.5" Toyo MT's, E&G Extended Flares, Full body tube steel exoskeleton, 5" Skyjacker lift, Amp Research steps, Gobi Roofrack and ladders, Smoked LED's, AFe CAI, Dynatech long tubes and cats, Magnaflow exhaust, Stock tune, 4.88 gears, Chrome Grenade Shifter, interior blacked out, rear captains chairs, Solar Power!!)
Old 06-26-2012, 02:19 AM
citiboy's Avatar
GM P/N 15592573 this is the stock keys for the 1500 trucks. I haven't install mine yet but it's pretty straight forward...you need a torsion bar tool to remove the keys and need to jack-up the front to remove the pressure from the torsion bar.....use extreme caution on this type of job....google is your friend for instructions on how to remove the keys.
Hope this helps!
Old 06-26-2012, 05:03 PM
guruerror's Avatar
Hope this helps!
I had a buddy put mine on a lift in his shop to swap the keys...it was a real pain getting the bars out. He had to heat them up with a torch to break them free from the stock keys.
CNTRY
DTOM
Old 06-27-2012, 04:01 AM
Crush'em's Avatar
Crush'em Crush'em is offline
Crush'em is on a distinguished road
What size wheels are they? Do you know the offset or backspace?
2007 Hummer H2 Yellow SUV
37"x13.5"x20" Toyo Open Country MT's, 20x10 Method Racing 301's, Fox 2.0 Performance Series Shocks, Truxx Level kit, color matched grill, (Almost) all chrome removed, Removeable U-steps, Factory All weather mats, Gobi flip-up front plate, Factory brush guard
