Old 08-11-2012, 05:51 PM
painguy's Avatar
painguy painguy is offline
painguy is on a distinguished road
Default 37 tires rubbing any advise please!
New to the h2, have had 4 h1's. decided to get an h2. the truck came with a key lift of 2.5 inches in the front and 1 inch in the rear. it had 32's on it i bumped up to 37.13.5.17 on stock 2003 h2 wheels.
front rub on all turns and rears rub every time i go over a bump. I am not sure what keys the previous owner used to lift it and what if anything he did to the torsion bars.
any help would be greatly apprciated as this is pretty much the only informative ACTIVE forum for the h2! thanks again
painguy
Old 08-11-2012, 05:54 PM
painguy's Avatar
Default Re: 37 tires rubbing any advise please!
some pics of my new truck(to me) and the prob areas.
Old 08-11-2012, 10:10 PM
devilsfan's Avatar
I ran 37s on stock for many years. All it took was a really good alignment, then no rub.
Old 08-11-2012, 10:35 PM
tyler1bo's Avatar
tyler1bo tyler1bo is offline
tyler1bo is on a distinguished road
Could be the backspacing of the wheels that causes the issue with it hitting frame.
'08 Birch White SUT
20X10" BMF S.O.T.A Wheels
38X13.5X20 Toyo Open Country M/T
AMP Research Steps
10" JL Audio sub w/ box and amp
Truxxx Lift 2.5" F-1.5" R
4" Rancho Lift
Corsa Sport Cat Back Exhaust
K&N Cold Air Intake
Spare Removed
RealWheels Eliminator Kit w/o hooks
Defenderworx hooks
Body matched grille
Ford Raptor 6.2L emblem
GS Creations Plexi-glass tail light and front turn tint
RealWheels Oversized Black Hood Handles
Recon Smoked Cab lights
More...
Old 08-11-2012, 10:49 PM
guruerror's Avatar
Agreed...I'm running 37x12.5s (with Truxx keys and a Cognito leveling kit) and had rubbing with the stock rims. The backspacing on the stockers are 5.5" if I remember correctly. When I switched to XD rims (same tires) with a 4.5" or 4.75" backspacing the rub went away completely.
You're prolly gonna have a slightly different experience since your rubber is an inch wider than mine...but I'd still bet that after market rims will fix you right up.
CNTRY
DTOM
Old 08-11-2012, 11:06 PM
tyler1bo's Avatar
Now rears are another issue..do you have bags or coils? Because bags are notorious for going bad and you may not be getting the amount of lift you need.
'08 Birch White SUT
AMP Research Steps
4" Rancho Lift
K&N Cold Air Intake
Spare Removed
Defenderworx hooks
Body matched grille
More...
