Old 01-27-2013, 09:12 PM
Hellz Hellz is offline
Default DYI Air ride recalibration
so i am wondering if there is a easy DYI way to recalibrate the air ride?
the shop did a calibration on it, but it sits about 3 to 5 inchs lower than it did before, which also is causing my headlights to aim higher, and i think is also the reason for the air ride message on my display.
i think it knows it needs to go a certian distance, but it is being stopped and popping a code.
so what you gus got?
taking back to the shop isnt a option as it is 1100 miles away, and they screwed me and removed the charge from the receipt, so basiclly they thought they could fix it and made it worse and basically said sorry...
Old 01-30-2013, 12:57 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: DYI Air ride recalibration
No way to calibrate it without a tech 2 scanner
1998 Chev Z71
2007 Chev Trailblazer SS
Old 01-30-2013, 01:00 AM
HUMTECH's Avatar
What exactley did they do? Reprogram the module or try to calibrate the ride height? Do you have the original single stage compressor or has it been upgraded to the dual stage compressor?
1998 Chev Z71
Old 01-30-2013, 02:48 AM
they adjusted the ride height.
as it is right now, her ass sits only a few inchs off the bump stops.
single stage compressor.
Old 01-31-2013, 08:20 AM
HUMTECH's Avatar
well it needs to be done again with a tech 2. No way around it unfortunatley
1998 Chev Z71
