Old 06-27-2013, 01:21 AM
jsbihn jsbihn is offline
Moderator
Default ride height air sensor mod??
I was reading an older post and it happened to mention an ride height air sensor mod for those who have air suspension in the rear.
Can anyone tell me what that is and what it does, and how to do it?
I tried searching for ride height air sensor mod and I only got the two threads that I read it in, to which they each say nothing of what it is, does, or how to do it.
Your help is appreciated
Old 06-28-2013, 08:42 PM
Moderator
Default Re: ride height air sensor mod??
anyone?
Old 07-21-2013, 04:16 PM
Bhplumber's Avatar
Bhplumber Bhplumber is offline
Bhplumber is on a distinguished road
Are you trying to adjust the ride height or get more clearance for wider tires on stock wheels? There is a thread somewhere on here I read about switching the links to the inside of the sensor and the trailing arm to clear 13.50 tires on stock wheels.
I modified my links to be adjustable. When I bought the truck someone had cut and lengthened the links by welding in a some longer rod. It looked like a 3rd grader did the welding. I cut the rod ends off leaving about 3/4" of the rod on each end. I JB welded the ends into an all thread coupling and cut some all thread to go between the 2 couplings with a jam nut on each coupler. Not that it could turn but it just looked more "factory". It did take a little trial and error on getting the adjusted so the truck set level both front to back and side to side. It takes VERY LITTLE adjustment to change the height so don't get crazy with making the to long for more lift.
I did read some here that you can take it to a GM dealer and have them program your computer to set the ride height as well. I'm guessing that would cost more then the $6.00 I invested and a couple hours of time.
05 sut stock - SOLD
06 sut rancho lift 37" BFGS - SOLD AND MISSED
05 sut - rancho lift, new airbags, 5100 bilstiens,37" toyos, the build is just starting!!!
