Old 09-10-2014, 11:12 PM
jsbihn jsbihn is offline
Moderator
Default A/C Shraeder Valve replacement question
Hey all,
I just replaced the shraeder vale on my 03 H2 on the low side (smaller valve), and when I went to replace the shraeder valve on the high side (larger valve) i noticed there was no valve there.
What was in the port look like a small ballon at the bottom being held in place i guess by a ledge. It seems valve like in that I guess I could push in and it would rebound out.
Does this sound right?
Or is there something there on purpose and I need to just push it down and install the valve
I have had A/C issues from day one of this truck, and I am wondering if it is because the low side valve leaked and the high side valve is not even there?
Help?
'03 H2 (name: Big Gulp)
Old 09-11-2014, 07:49 PM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: A/C Shraeder Valve replacement question
High side valve is non serviceable, need to replace line
1998 Chev Z71
2007 Chev Trailblazer SS
Old 09-12-2014, 02:24 AM
Moderator
ok wait, i dont know if the high side is suppose to have a valve or not.
it almost looks like there is a ball pressed up in to a hole, and if you press the ball down it opens up the line.
(almost like a ball on a spring... ball seals the opening because it is pressed up into the port, push the ball down and it opens it and then you release and it closes)
I took a screw driver and pushed and when i did it did release pressure/ air/ freon....
so i am just checking to see if this is correct or if some how there is suppose to be a shraeder valve there and it was blown out
(btw, I can come to think that if this ball / springs setup is actually the way it is from the factory.... then basically by looking at it... it wouldnt be a serviceable piece)
Please let me know what you think
if you need a picture I can try to get one
Old 09-13-2014, 12:10 AM
HUMTECH's Avatar
That is supposed to be exactly the way you describe it. Is why its not serviceable
1998 Chev Z71
Old 09-13-2014, 06:02 PM
Moderator
Thank J-man
I figured but I wanted to make sure.
Service manuals arent that detailed with pictures
