Old 09-06-2015, 03:39 AM
cmd's Avatar
cmd cmd is offline
cmd is on a distinguished road
Default Shift lock assembly/solenoid. Stuck in park
Does anyone know how to diagnose if the the solenoid is energized and not working. A diagnostic chart on how to test at the harness on the shift lock assy is what I'm looking for.
Stuck in park , have to manually push in the solenoid now at all times .
Old 09-06-2015, 01:23 PM
citiboy's Avatar
citiboy citiboy is offline
citiboy is on a distinguished road
Default Re: Shift lock assembly/solenoid. Stuck in park
inspect the shift solenoid connector for broken wire, had that happened to mine.
good luck!
2008 Hummer H2 Luxury Edition
Toyo MT 38x13.50x18 on Rockstar. Green keys. 2" rear spacers. 1" bodylift. Cognito UCA, steering bracket, front stab links. Bilstein 5100 shocks & steering stab. Moog inner/outer TR, pitman, idler arm & bracket with remote zerk. E&G Classics fender flares. ARP 434-1301 ex. man. stud kit. Airaid perf. air filter. Crown brake lines. Warn PowerPlant HD. Rubberduck UCP. Gobi Ranger roof rack. DDM Tuning 55W HID Hi/Lo headlights. Hella fogs. Evans waterless coolant.
Old 09-06-2015, 02:02 PM
Easy Ed Easy Ed is offline
This help ?
From here...http://www.elcovaforums.com/forums/s...ad.php?t=36444
Pin
Wire Color
Circuit No.
Function
A
BLK
1050
Ground
B
LT GRN /BLK
584
Park Lock Control Solenoid Supply Voltage
C
YEL
1996
Remote Shift Selector Signal
D
Not Used
E
DK GRN /WHT
1135
A/T Shift Lock Control Solenoid Supply Voltage
F
PNK
1020
Ignition 0 Voltage
Old 09-09-2015, 05:55 AM
lasvegash2's Avatar
lasvegash2 lasvegash2 is offline
lasvegash2 is on a distinguished road
Same thing here. Gm makes a repair harness for that. It was $20 and no more worries.
scott j.
2008 h2 sut
2008 escalade
1969 charger
Old 09-10-2015, 02:58 AM
cmd's Avatar
cmd cmd is offline
Thanks guys. It wouldn't go out of park for a few days, then when I had time to diagnose it worked when I got in the truck the next morning.
Oh well next time
2003 h2
6" Fabtec lift
18x9 ultra wheels
37" Mickey Thompson mtz
2005 h2
Blacked out
Procharger Dsc1 supercharger
JBA headers/Exhaust system
20x10 ultra wheels
Old 09-12-2015, 01:48 PM
HummerMann's Avatar
That can also happen with a weak battery.
Hummer, like nothing else
Old 09-17-2015, 07:54 AM
twenty2's Avatar
twenty2 twenty2 is offline
What's the proper name of the harness needed?
Old 11-21-2015, 07:54 PM
cmd's Avatar
cmd cmd is offline
Angry Re: Shift lock assembly/solenoid. Stuck in park
Thanks again guys, I however still have yet to resolve this issue.
So intermittent, happened yesterday and today once again it's working. Got out the schematic and the meter and the damn solenoid is working today. Haven't found any voltage issues to the pin plug as far as broken or damaged wires.with my meter at the solenoid power and ground I played around with the harness and seen no change in the voltage.
Can't wait to get the licked once and for all.
2003 h2
6" Fabtec lift
18x9 ultra wheels
2005 h2
Blacked out
20x10 ultra wheels
Old 01-11-2016, 09:42 AM
SuitedSpikes SuitedSpikes is offline
SuitedSpikes is on a distinguished road
Where can I buy one of these online?
I 'fixed' mine 6 months ago but it's beginning to act up again.
Old 01-25-2016, 06:18 PM
twenty2's Avatar
I think this is the right one to fix the problem... http://www.ebay.com/itm/AC-Delco-PT3...YAV 5&vxp=mtr
