Old 05-27-2004, 10:02 PM
Alley Alley is offline
Alley is off the scale
I am going to be changing my spark plugs soon. I have never trusted stock plugs and usually always change them in my vechiles after a few k miles. What is the proper gap for our spark plugs with stock HP? And are these Beru Performance plugs just as good as any? Or is there another brand you guys would recomend? Thx.
Old 06-23-2004, 10:24 AM
Dan Dan is offline
Are you sure you didn't search for "gape"?
Old 06-23-2004, 03:33 AM
Iridium:
http://www.pacific-audio.com/perform...es/267866.html
A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
Damn, I thought I could find it with a simple search on the web. I guess "gap" means different things... I can't believe it is not in the owner's manual. Or is it? I cannot check right now.
Old 05-27-2004, 10:19 PM
Bevo Bevo is offline
Bevo is off the scale
Beru Silverstones are the way to go!
Yellow 03 Adventure w/black Grill, UM8 Touch Screen Navigation Radio, U2K XM Digital Radio, Remote 6-CD Changer, JBA Titanium Headers, Corsa Off-Road Sport, Airaid Filter & MIT, Nology Wires & Plugs, S&P Pro-Flash, Warn 9.5ti w/X-Line, Toyo Open Country M/T 37x13.5.
Old 05-27-2004, 10:16 PM
Yetti Yetti is offline
as much as I like hypo stuff the best plugs for your ride are going to be AC's. if you can look to see if you can find an Iridium plug, they will out last & out perform every other plug out there.
Yetti
www.greatlakes4x4.com
www.wegotmud.com
www.glfwda.org
Old 06-23-2004, 12:32 PM
Dan Dan is offline
A google image search for "gape" turns up some interesting stuff
Old 06-22-2004, 09:13 PM
So does anybody know the stock gap? I was thinking about a .050.
Old 06-23-2004, 12:08 PM
I just made the difficult trek out to the garage to look in the underused Owners Manual and lo-and-behold what do I find on page 6-68, the spark plug gap. I was starting to get worried that it did not exist. Maybe there wasn't a gap at all.
Dan, now I know what I did wrong. Thanks, I may never have found it.
