08-21-2004, 09:06 PM
This was taken off of Humvee.net I just thought some of you might be interested.
Well, I had a good talk today with the folks at one of the top diesel shops
in Salt Lake City and they told me that someone had brought in an H2 -- with a Duramax for work.
They said, yes, they know that supposedly it is not supposed to fit nor the
transmission -- but despite what the factory, GM, and everybody else has
said, they do fit and that they've seen it.
Apparently, the owner of the H2 purchased a Duramax truck and then removed
the engine and transmission from it and dropped it into their H2. The work
was done by a regular (gas) shop in Layton Utah.
These folks are incredibly knowledgeable and if they say it, I am very
inclined to believe it. They are magicians when it comes to diesels and
can do most anything if it can be done.
So, there you have it -- the Duramax can indeed fit in the H2. Perhaps
with not a lot of extra room (both of us wondered about cooling), but it
appears as if it can be done.
-Art
2000 Ford F-250 Diesel
1997 Ford Exploder
1999 Suzuki RM250 completely gone threw by Pro-action.
-Art
1997 Ford Exploder
10-03-2004, 08:44 PM
Here are some pics of the H2 I mentioned that will be at the SEMA show this November in the Edge booth. BTW, Lyndon Wester of Westers Garage did the programming on it. Duramax H2
08-22-2004, 01:13 PM
http://www.amgeneral.com/vehicles_gep_productinfo.php
I think this is the motor Kaskar is using in the conversion H2.
A super-charged OPTIMIZER 6500 is the perfect answer for those who demand the ultimate in power. This top-performing diesel engine provides better fuel economy than most “big block” gasoline V8s, while producing more than 300 hp at 3500 rpm.
Check it out.
CONFIDENTIALITY NOTICE: This post and any pictures posted with it are the property of Adam in CO and/or his affiliates. The contents of this post are confidential and may contain information that is privileged and/or exempt from disclosure under all
08-23-2004, 06:46 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Steve R:
Course, when I smell diesel it always takes me back to the stern of a boat where a tuna, yellowtail or dorado are about to meet their demise...  <HR></BLOCKQUOTE>So, Steve, is that an invitation?
08-23-2004, 10:23 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Hmmmm....for $20 I can get you a looping CD of diesel-sounds you can play really loud on your radio and for an additional $10 I'll throw in a "diesel fuel only" sticker for your fuel cap!
And if you act now we'll include a set of fragrance scents which will fill your cab with the scent of buring diesel fuel. Refills available!
Other accessories include a CD of assorted mechanical failure sounds; you'll get "snapped tie-rod (courtesy of some video circulating world-wide), burning tire rubber for lack of traction, "pop goes the diff", "clunk goes the under-frame" and my favorite "blam goes the skid-plate". <HR></BLOCKQUOTE>
ROTF    .
08-22-2004, 01:11 PM
My friend has a 3500 crew cab with a 471 Detroit & Allison trans. but it doesn't make it right?
I would prefer putting a cummins and a 6 speed in one over the duraturd.
08-24-2004, 03:39 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Camper Bob:
Also, while the LPE beast sounds like tons of fun, one has to wonder about the distinct possibility of throwing driveline bits as far the eye can see upon romping on the GO pedal.. <HR></BLOCKQUOTE>I think a certainty would better describe that.
08-24-2004, 04:21 PM
08-22-2004, 01:43 AM
As I said Livin i copy and pasted this for the humvee.net forum. Therefore i have no evidence. I thought it might be interests some people.
Thomas S
1997 Ford Exploder
08-23-2004, 02:31 PM
I'd kill myself with that much power, plus it would just be too money buying tires all of the time.
I would like to see the diesel in the H2 as an option but would not want to give it a shot as a retro-fit.
The answer to your question as to why...because they can...why else? It certainly can't be any practical reasons.
08-22-2004, 11:42 AM
Tom S is correct. Wait for the SEMA show in November.
08-22-2004, 02:57 AM
Actually, go to:
http://www.real4wd.com/content/page-events.asp
Kascar is unveiling their supercharged diesel H2 on Saturday, September 25. They don't say if they used the Duramax or not, however it should be interesting...
-HUMMERDOGG
-Art
1997 Ford Exploder
08-23-2004, 01:23 PM
Hey Seth, the full LPE package is $55,000.
700 Horsepower @ 5,200 RPM
740 lbs – ft of torque @ 4,600 RPM
All wheel drive or 4 wheel drive
Complete 427 CID engine and turbo package includes:
Two true ball bearing turbochargers
High efficiency air to air chargecooler
4 into 1 custom stainless exhaust manifolds
Two K&N 360 degree conical air filters
Turbocharger water feed and return hoses
Turbocharger oil feed and return hoses
Custom 7.0 L aluminum C5R block
CNC porting and polishing of LS1 cylinder heads
Billet steel connecting rods
Forged 4340 crankshaft
Forged aluminum pistons
Custom hydraulic roller camshaft
High performance valve springs
Stainless steel one piece heavy duty intake 2.02” 1.60”/ inconel exhaust valves
Three angle valve job, checking of spring tensions & heights
Computer balanced rotating assembly
Reassembly and blueprinting of engine
Properly sized fuel injectors and high capacity fuel system
Professional installation, testing and PCM recalibration
LPE's 2 year / 24,000 mile warranty
Original engine long block in exchange
Engine package installed $55,975.00
http://www.lingenfelter.com/performance427suvturbo.asp
But of course this requires and engine swap as well.
08-22-2004, 12:32 AM
Ya right. Show me pictures, receipts or something to verify this. I say not possible. The frame of the H2 will not accomodate the Duramax and Allison transmission. There is not enough room. I say BS....Till you prove otherwise....
08-24-2004, 05:06 AM
Paragon....
Your in MS. Dude....what are you going to do when a Tuna takes your 50-pound line and dives down so fast that your reel is singing and you've got your drag already set to max?
When your bicep is about to explode, your back about to cramp and your only 1/2-way through a 30-minute battle to bring that fish even near the boat?
YOUR DAMN RIGHT IT'S AN INVITATION!
let me know when your in/near town!
Kev....you know I've got that "blam goes the skid-plate" song well memorized. You've got a baby-scratch compared to my well-played plate. I can't even read the "H2" anymore....
10-03-2004, 09:07 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Livin' Large:
Ya right. Show me pictures, receipts or something to verify this. I say not possible. The frame of the H2 will not accomodate the Duramax and Allison transmission. There is not enough room. I say BS....Till you prove otherwise.... <HR></BLOCKQUOTE>
08-24-2004, 03:52 PM
Even though I don't have that 700 hp TT, just the younger brother, I was concerned about bits of my driveline also. Up grade the transmission. That's it. Don't worry about the axles. The tires just spin right away.
10-04-2004, 10:57 AM
I want one!!!
Hybrid Mode
