Old 03-21-2006, 11:52 AM
KorkedBatz KorkedBatz is offline
KorkedBatz is off the scale
My GPS icon on my Nav screen (right under my North arrow) keeps appearing on my screen and then turning off. This seems to be happening alot more since I got my axxess ipod interface installed. Any ideas on why it is doing this? Thanks
Old 03-22-2006, 11:50 AM
Thanks for the info....
Old 03-22-2006, 08:26 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Originally posted by Screeper:
Mine does the same thing and started to do it after install of xm radio. It means your GPS signal is weak possibly from electronic interference. No cure other then removing the electronic devices. Since my Nav works as well as before I do not worry about it, although it did bother me for the first couple of months.
X2. Everytime I run my IPOD
Old 03-22-2006, 10:44 PM
Klaus's Avatar
Klaus Klaus is offline
That's why I junked the OnStar and used the OnStar's GPS antenna for the NAV unit.
Old 03-23-2006, 10:26 AM
zeros zeros is offline
zeros is off the scale
where is the gps antenna located... can you plug in the onstar one instead ... i just figured they shared the onstar one ?
Old 03-21-2006, 08:26 PM
Screeper's Avatar
Screeper Screeper is offline
Screeper is an unknown quantity at this point
Old 03-23-2006, 11:26 AM
Klaus's Avatar
The NAV GPS antenna is mounted in the dash, and the OnStar GPS antenna is mounted on the driver's side roof.
The connectors are different, so you will have to make a custom adapter cable.
