Old 08-28-2005, 08:30 PM
JHALL JHALL is offline
JHALL is off the scale
i am going to add the factory tnr to my 03 h2...i have the new antenna ....the nav antenna and am wondering exactly where to mount it....it looks to be a flat metal piece with a wire going to the back of the radio....any idea where this antenna mounts?.....thanks again...jody
Old 08-29-2005, 12:07 AM
LoLo's Avatar
LoLo LoLo is offline
LoLo is off the scale
On the '05s, it is in the position of your current antenna. I have seen a couple of times that the guys have mounted it on the dash as close to the windshield as possible.
___________________
05 Desert Sand H2 Adv
Old 08-29-2005, 06:18 PM
thanks for the info but will that peice where the passenger side airbag switch is just pop off without removing the oh sht handles?....thanks in advance
Old 08-29-2005, 02:10 PM
Hummertech is off the scale
Assuming you're talking about the GPS antenna for a factory radio, it mounts underneath the
dash about 12 inches to the passenger side of the radio, you'll have to pull off the trim piece that has the oh **** handle and the airbag switch off to install it. you'll see the hole once you get that piece off.
