Old 12-09-2002, 05:23 PM
NSXTC NSXTC is offline
NSXTC is off the scale
For those who want a simple plug-n-play kit to wire your DRLs with headlights, go to:
http://www.painlessperformance.com/relays.htm
They have distributors everywhere that can sell the kits. I've seen it as low as $28 (http://www.ricksspecialties.com/). Everything you need. It's the 30803 AUXILIARY LIGHT RELAY KIT. You can use the included switch or by-pass the switch if you want to turn it on with the parking lights.
BTW, Street Rod Builder (Jan 2003) has a great tech section on wiring your lights. 'Bright lights wired right' on page 66.
Gives you info and sources on how to wire aux. lights and stuff.
The tech article may be on line later at http://www.streetrodbuilder.com
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
Red metallic, Lux package, Poron backup sensors, throttle body by-pass, Independent dual DVDs, Volant air box, DRL mod, chrome hood handles and latch.
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
