Old 01-29-2005, 03:56 AM
LasVegas LasVegas is offline
LasVegas is off the scale
I've noticed some interest in the express sunroof on some of the newer H2 for '03's. Here's a link to a product that may work if any are interested.
http://www.autoloc.com/detail.lasso?itemid=WC1000 Talk to Tom @ ext 312
Got it today, installed & works GREAT! One touch & it opens all the way. One touch & it closes. One more touch & it tilts open. Just touch anywhere while it's traveling & it stops there. Great upgrade for only $40 bucks plus shipping. Here's pics & some hints to shorten install time. Oh I need to add to the install instructions the processor is small enough to just lay inside the overhead console. Enough foam it won't rattle. <span class="ev_code_RED">My H2 is an '03. Confirm the wiring in your H2 is the same before making connections.</span>
Install revised 3/20/05. The following is current</span>
Jonahs
Old 02-04-2005, 12:48 AM
Got it & installed. See 1st post above for pics/install. Works GREAT!
Jonahs
Old 02-09-2005, 07:11 PM
Anyone else got their "gadget" & installed yet? Just curious if you're as happy with it as I am.
Jonahs
Old 02-04-2005, 04:48 PM
Yeah Bill, Tom's a real nice guy. Talked with him this morning & warned him he's probably going to get lot's of orders on this item. He assured me he'll keep plenty in stock for us. They appreciate our business.
Jonahs
Old 02-04-2005, 05:16 PM
Well Vegas what the heck is going on with You. The detail of instruction for this instalation is way below Your normal instruction quality. I mean You have a whole herd us of that have come to expect a much more from you. May i suggest that even though a child should be able to figure out what You have discovered for us that perhaps You post another thread to cover the install in more of a step by step to help make the job even more easy.
But, I leave it to You as to whether You can tolerate the poorer quality instruction. I'm not saying bad instruction but poorer compared to You normal level. I can live with it if You can. Many thanks for the effort to solve this problem. I ordered Mine today so I have 5 to 7 days to wait on it so that gives You time to improve the instalation directions.
Thanks for all Your effort and help!!!
I also talked to Tim he is ready for everyone.
TAZ
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by LasVegas:
I've noticed some interest in the express sunroof on _some_ of the newer H2 for '03's. Here's a link to a product that may work if any are interested.
Got it today, installed & works GREAT! One touch & it opens all the way. One touch & it closes. One more touch & it tilts open. Just touch anywhere while it's traveling & it stops there. Great upgrade for only $40 bucks plus shipping. Here's pics & some hints to shorten install time. Oh I need to add to the install instructions the processor is small enough to just lay inside the overhead console. Enough foam it won't rattle. <HR></BLOCKQUOTE>
Old 03-11-2005, 01:45 AM
DICK-M DICK-M is offline
DICK-M is off the scale
After reading your information I bought one these units and wanted to have a Shop install it, but they gave some crud about Auto-Loc's instructions. So I printed out your instructions and did it my self in less then a 1/2hour and it worked Great. So Thank You Very Much for your Great Direction.
Old 03-20-2005, 07:33 PM
When I intially installed mine i had trouble with it opening but would close well. I did as Vegas said and went back with a meter and checked voltage at connections and the open side voltage would vary as I moved wire around. Rewired and worked perfect. The way it acted and having just installed i suspected My work first. The quick connects have for Me always been problamatic and I tossed them and went with inline connect to assure I had connections and all is OK.
TAZ
Old 02-04-2005, 06:59 PM
mmayo mmayo is offline
mmayo is off the scale
THANKS!!! Ordered mine!
Old 03-20-2005, 10:29 PM
<span class="ev_code_RED">Minor revision to wiring installation. See first post of this thread. For those that have installed per first instructions you do not have to change unless you want to. Will work fine as wired.</span>
Jonahs
Old 02-11-2005, 04:54 PM
H2 Bill H2 Bill is offline
Mine actually opens to the first stop and then one more touch all the way open. Mine's an '03.
1994 Chev Suburban Blown
Old 02-10-2005, 12:14 AM
Just installed it!! It works great! It took all of 20 minutes after I figured out that the console has phillips screws and not torx!
Thanks again LasVegas, this was a great find.
Old 03-11-2005, 05:59 PM
rvs9 rvs9 is offline
rvs9 is off the scale
Where did you position your new control module in the overhead console? I have my XM radio tuner mounted in the front of my console and sits in a cut-out on the console. I guess what I am saying is that the front space of my console is taken up and am not sure if I will have room for the module.
Old 03-19-2005, 11:48 PM
JMV1210 JMV1210 is offline
JMV1210 is an unknown quantity at this point
Las Vegas,
Put mine in today and it works well, but I noticed when it moves to auto close, it stops before it gets all the way in and does not seal. In fact when it opens it open relatively fast, but on close it’s slow.... If I assist the sunroof with my hand by applying pressure the sunroof will close all the way and seal.
Thoughts?
Old 02-12-2005, 03:28 PM
Mike (by the beach) Mike (by the beach) is offline
Mike (by the beach) is off the scale
Thanks for the great find -- I got it from ebay for $30 + $6 shipping.
Old 01-31-2005, 06:45 PM
intimidator, If I read your post correctly, I should be able to purchase the module and switch for some '05's and change them with the ones on my '03 and have an express roof. Is that correct?
Old 02-11-2005, 01:38 PM
finbox finbox is offline
finbox is an unknown quantity at this point
Las Vegas,
With your mod will it open to the first stop or all the way open?
Thanks,
Finbox
Old 01-30-2005, 10:22 AM
intimidator intimidator is offline
intimidator is off the scale
i am a gm tech. i whent on techline and checked 03' 04' and 05.none have express sunroofs. the sunroof mentioned in the other thread probobly is not factory.
Old 03-11-2005, 06:17 PM
Thanks LasVegas. Just ordered mine. As I do not keep alot of electrical doo-dads around the house, what materials will I nned in addition to wire cutters and electrical tape (i.e. # of quick clamp-on connectors, etc..)?
Old 02-05-2005, 12:14 AM
Fever Fever is offline
Fever is off the scale
Hey LV you should ask for your money back for all the business you sent them I ordered mine today By the way GREAT job on the instructions that will help alot. Maybe you could talk to Warn
Old 02-04-2005, 03:08 AM
True, true. Maybe I should look at it in the morning. After a glass of OJ, not Beer.
