Old 11-15-2003, 04:40 AM
Hummertime Hummertime is offline
Hummertime is off the scale
8900 miles and driver side power seat just quit! hour and half to dealer...anybody know bout this?
Bone stock but dreamin!
Just getting started!
03 white lux
silverstar bulbs
Old 11-15-2003, 05:41 AM
ZeroTolerance ZeroTolerance is offline
ZeroTolerance is off the scale
Hey no prob, I will defend you man... I take care of my fellow H2 owners......
Old 11-15-2003, 05:40 AM
HUMMERDOGG HUMMERDOGG is offline
HUMMERDOGG is an unknown quantity at this point
Yeah, my self control is me not kicking that guy's dumb ass... I would love to see that he lives in Houston... Ahhh, just the thought of a nice ass whooping makes my heart flutter and my pulse quicken.... ever so slightly mind you since he is just a lawyer and all...
-HUMMERDOGG
Old 11-24-2003, 12:13 AM
AUBURN H2 AUBURN H2 is offline
AUBURN H2 is off the scale
I have had the same problem with 2 different H2's. In both instances I was able to pull the fuse for the seat, reinstall it and the seat returned to normal operation. I do not remember which fuse it was but you can find it listed in the owners manual.
Good Luck!
Old 11-22-2003, 11:44 AM
Centerfire is off the scale
Short answer "Yes".. My usually windy answer: I took my H2 in for a leaky oil pan, driver mirror would not move in or out and I casually mentioned that I believed the drivers seat didn't stay in the correct postion. I picked up the next day and they had replaced the oil pan. drivers mirror and Drivers memory thingee for the seat.. that has been 2 months and no further problems. Hope that helps.
Mike
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by MAC:
Bayou, Hummer dealer is the only right place to go and it is FREE. People here are nice and friendly, but information even correct is often not useful. I am interested to know did any dealer fix this seat memory problem for good for anyone here? the problem is common. My dealer is only 3 miles away, nice and friendly and got everything done on time, but I don't know why I just haven't talk to them about this issue in my 4-5 oil change and lub services. For some reason, I don't think they have a fix for it. My thinking does not make sense.
At least I know my heated seats are working, I used the driver seat heating for the first time this week, after 14 months. We didn't use the function on several ski trips, just didn't need it and never thought about it. I will try to remember using them on next week's ski trip.<HR></BLOCKQUOTE>
Old 11-15-2003, 09:44 AM
Hummer Man is off the scale
Check the plug / connector - under seat left rear!
Old 11-15-2003, 10:07 PM
good fuse...plug ok under seat...damn i guess its off to the dealer. thanks anyway guys!
03 white lux
silverstar bulbs
Old 11-15-2003, 04:42 AM
Same thing happened to my brother's QX4 earlier this summer when he was down. One of the plugs had come lose underneath the seat. If you haven't done this, make sure there are no loose connections...
-HUMMERDOGG
Old 11-21-2003, 03:33 PM
MAC MAC is offline
MAC is off the scale
Fortunately for me, my seat memory loss happens once every few months, I just accepted it and live with it. Takes seconds to reprogram it. I think it used to happen in shorter period, not sure. But if it happens every few days as you reported, that would be very annoying and must be fixed by the dealer, you just have to take it back to the dealer again and again until they get it right. Since it moves, I doubt it is the motor, usually it is the computer chip or program.
14 months 20,000 miles. Hummer drives better and better.
Old 11-23-2003, 06:29 AM
argonaut argonaut is offline
argonaut is off the scale
Mac, my heated seats are awesome around here, I use them all the time because I am freezing otherwise in my truck. Damn cold fronts...
Old 11-23-2003, 08:32 PM
unaslob unaslob is offline
unaslob is off the scale
my easy exit function hauled off and stopped working as well.. i cant understand why it did that, i tried reprograming the seat, nothing.
the function is clearly on, just not working?
HOW DO YOU RESET THE COMPUTER IN THE h2???
it might reset to the factory settings.
Other thing i find annoying, is that what determines the seat memory and the truck setup. I took me awhile to figure out that it was the remote locker, NOT the key.
unaslob
Old 11-23-2003, 04:22 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I'll try the dealer again, and again till they get it right!
Maybe, I'll just get me a bucket to sit on, atleast I know it'll be in the same position every time!! Ha Ha!
www.meatspin.com
Old 11-22-2003, 05:35 AM
Bayou H2's Avatar
Bayou H2 Bayou H2 is offline
Bayou H2 is off the scale
I am having issues with my driver’s seat as well. My seat quit adjusting to allow for easy exit today. The seat back still reclines but the seat bottom no longer goes down. Does anyone know the repair for this problem? Thanks.
'03 White H2 Lux Package
Old 11-23-2003, 08:48 PM
MAC MAC is offline
This is my No. 2,500th post. If none others are Hummer related, at least this one is.
Frankly I am quite confused about the settings, but I think:
1- It is the FOB not the key. The key is just a key, no memory nor nothing.
2- Seat stays in last driver's position(1 or 2), unless when it forgets and tries to kill me like the Starwar garbage disposal.
3- To reset, you cannot do it any time just by pushing and stay at #1 or #2 button until it beeps twice.
4- To reset, in my Hummer.
a- In PARK. Push PERSONALIZATION button on steering wheel, lower righ side column.
b- SEAT POSITION RECALL show at DIC on dash. DRIVER 1 on DIC.
c- Move your seat to correct position.
d- Push #1 button on door, stay until it beeps twice. DONE.
e- Pull out key, move your seat to desired EXIT position.
f- Push EXIT button on door until it beeps twice. DONE.
That works for me every time, until it forgets a few months later.
03 white lux
silverstar bulbs
Old 11-23-2003, 08:17 PM
MAC MAC is offline
Dear Hot Gas, ever been to a ski resort? you know where you see the most Hummers? H1s and H2s? Tahoe! We are everywhere. Do you know how often we have to wave back to other 4x4s, especially Jeeps and Rovers, they are the most friendly ones toward Hummers, my arm gets tired from waving like the Queen of England. Ever casually drove out of deep snow while others look with envy? Then you know what is a Hummer made for. Some like to go around and around in dirt or mud and drink beer with dirty men, some men like men, fine with me, that is not my biz, I like snow and I like wine and I like women.
Old 11-15-2003, 04:03 PM
MAC MAC is offline
How does a seat "QUIT"? Please be specific. A seat does not quit, it may be forgetful which is common in almost all electric/memory car seats, especially German and English cars. If that is what you mean, then my driver seat does that every 3-4 months. No big deal. PARK. At DIC, push the top button on lower right steering wheel column. DIC says DRIVER 1, then SEAT MEMORY. Set your driver seat position, push button 1 for few seconds until it beeps. Do the same thing a few months later.
If it just went DEAD, then a simple fuse or connector problem could be it.
Of course, you can get really angry about this, jump up and down and demand an apology, instant repair or replacement of seat, but that wouldn't help much.
Old 11-21-2003, 03:09 AM
RIC-H0's Avatar
I have has lots of minor problems with the driver seat memory.
It begins to drive in the forward direction, but never makes it to the origanal position.After I reprogam it, it'll last for about a day or two.
I have taken it to the dealership twice. The 1st time they changed out the module, second time the reset something(Can't remember exactly what it was).
A few days later, it sure enough would not go back to the set position.
Is it possible to have a defective drive motor in the forward position?
Am I getting taller and shorter in 3-4 day intervals?
Help!
www.meatspin.com
Old 11-22-2003, 06:43 AM
MAC MAC is offline
Old 11-15-2003, 05:35 AM
Maybe you drove it HD and broke it.....hahaha What no Self Control....
Chinese buffet guy: HD you be here 4 hours eat whole buffet, you go you go....... hahahha
