Old 06-14-2005, 06:36 PM
H222 H222 is offline
H222 is off the scale
ok here's the skinny--ordered 22" wheels for my black 03 lux package. now i need to make a decision on tires. want to run 37x13.5r22 toyo's or nitto's. anybody got this setup? anything i should look out for ridiculous amounts of rubbing? etc. any help here would be great
03 Black Lux Package
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
www.solidperformanceinc.net
Old 06-27-2005, 05:12 PM
hey thanks for the help guys actually just got my rims and tires put on today went with
22"demoda concept intimidators in hyperblack
and
37x13.5r22 nitto mud grapplers will post pics as soon as i get done removing side steps
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
Old 06-15-2005, 02:53 AM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H222:
ok here's the skinny--ordered 22" wheels for my black 03 lux package. now i need to make a decision on tires. want to run 37x13.5r22 toyo's or nitto's. anybody got this setup? anything i should look out for ridiculous amounts of rubbing? etc. any help here would be great </div></BLOCKQUOTE>
Please use the find function. All of the questions have been covered here many times.
Thanks and welcome!!!
Old 06-28-2005, 02:42 PM
Boar-Ral Boar-Ral is offline
Boar-Ral is an unknown quantity at this point
pics are up check it out
http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=260601...381075921#238 1075921 </div></BLOCKQUOTE>
Nice! These are the tires I was looking at, even the same size. Are you getting any rubbing with them? I was a bit worried, because I was told 37 x 12.5 was the largest you could use, and even then there was some rubbing. What do you have to say about it, since you're actually using them? The lugs are so large I would be afraid of tearing things off if there was too much rubbing.
Old 06-18-2005, 12:54 AM
glennc glennc is offline
glennc is off the scale
...continued...
...so with that large a rim and the inch wider tires you will more likely have issues (the worst combo to potentially hit). It also depends on how much rubbing you will tolerate. It also depends on your particular H2 since it appears that there are some differences between individual cars for tolerances. Hope that helps a little but definitely try the FIND function for more expert feedback for you.
\'05 H2 SUV, LUX, Stealth Gray
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
Old 06-28-2005, 02:44 AM
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
Old 06-27-2005, 06:20 PM
W1N's Avatar
W1N W1N is offline
and
37x13.5r22 nitto mud grapplers will post pics as soon as i get done removing side steps </div></BLOCKQUOTE>
Great! I'll be looking forward seeing those pics. Let us know how is it with rubing and how much those extend outside the fenders.
Thanks!
Old 07-02-2005, 12:57 AM
well the tires do rub but not that bad. i've had vehichles with worse. only at full lock in reverse i get somewhat nervous. i think cranking my torsion bars will help with that will let everyone know as soon as that's done
22\" intimidators
37\" mudgrapplers
HID\'s
www.tintmasters.net
www.boozemob.com
Old 06-18-2005, 12:52 AM
Good tip to use the FIND function.
To try to help (with my somewhat limited knowledge on the topic), my two cents so to speak, it sounds like tire height and width need to be considered along with rim diameter. The large the rim the more likely a wider tire will hit since the "bulge" part of the tire is more closely located to items with less clearance.
