03-21-2004, 04:14 PM
Wanted to keep a clean looking H2. Didn't like xd9000i sticking out so far in front. Will write up how to build mount if anyone interested. No drilling or welding to mount to H2. You use two 1/2" bolts,sorry I think 19mm spare tire mounting bolt holes.
Vern
[This message was edited by It's a Dry Heat on 03-21-04 at 10:39 AM.]
Vern
03-29-2004, 07:59 PM
David,
I tried to post some photos, however when I sent it said they were too large of file. I will retake photo's in next few duas and resend. However if you want me to send directly to you send me an e-mail at mboard@flash.net
Vern
03-30-2004, 02:04 AM
here is photo of 15,000 lb Warn
03-30-2004, 01:36 AM
oma,
I have the SMA spare tire mount and the rear wired for the multi mount winch. You can use it but you have to open the spare tire to mount it.
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
03-29-2004, 02:55 PM
I found carting around of winch to be a pain and not strong enough. Had a custom job done with 15,000 lb Warn
03-30-2004, 01:34 AM
mboard,
If you can resize them and post that would be great so every one can see. If not you can email them to me at wag61@aol.com
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
03-29-2004, 05:22 PM
mboard,
Post some pics please  .
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
03-22-2004, 04:55 AM
I just put mine on the floor in the garage when I don't think I will be having any use for it. I know the last time I needed it, it was shoved into the ground and there was no way to install it at that point in time. Just make sure you install it BEFORE you hit the trail.
Nice job on it, it looks good there. But if I put mine there, the sixth pasenger will not have anywhere to get me a beer from.
________________________
This place sucks now, bye.
03-29-2004, 11:49 PM
I'm looking at buying the multi-mount winch but I have the outside mounted spare tire. Has anyone tried to use the winch in the rear receiver with the outside tire mount? Does it fit? This is why you put the spare on the roof, isn't it!
Hybrid Mode
