Old 11-01-2005, 02:19 AM
Andre Andre is offline
Andre is off the scale
when i go over bumps or pot holes ect... i hear
some creaking noises...anybody have a fix for this?
Old 11-01-2005, 01:39 PM
W1N's Avatar
W1N W1N is offline
W1N is off the scale
I have an odd flexing noise when I drive slow i can hear it. It sounds like dry bushings. </div></BLOCKQUOTE>
I testdrove a new 2005 SUT in Denver six weeks ago, and it sounded really "lazy" over bumps. It had that weird little squeeking noice over every bump...
Old 11-01-2005, 06:12 PM
Dan Dan is offline
Mine made that loose chain/ball-bearings-in-the-muffler noise. It was the heat shield on the muffler. The dealer installed a big clamp around it and it stopped.
Front end its most likely the skid plate. If not try the crossmember bolts, then the lower a-arm bolts.
Old 11-01-2005, 12:00 PM
VTSTOMPER is off the scale
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 11-01-2005, 05:26 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by gcraybas:
I have a 2006 suv. I am noticing a flex, creek, loose chain noise at speeds under 10 mph. It sounds like it is coming from the l rear tire area. I was thinking it was from the release of brake pressure. It also sounds like a loose shield. I can reproduce the noise by lightly accelerating from a stop with a slight turn of the wheel. I crawled under and all shields appeared to be tight. I brought the H2 into the dealer and they stated "Operating per design". This is driving me nuts. You can hear it over the radio. I know there is something wrong, I have been told by bystanders that something must be loose. I am bringing the H2 back in for service this afternoon. Any info on what I should tell them to check? </div></BLOCKQUOTE>
I know from past experience that catalytic converters will rattle sometimes. Do you have an aftermarket exhaust? Maybe it's just tweaked enough to vibrate on something.
I munched mine on a rock in Moab, and now it vibrates against the bottom of the bumper. Drives me nuts!
Old 11-01-2005, 01:09 PM
gcraybas gcraybas is offline
gcraybas is off the scale
Old 11-01-2005, 11:40 AM
Hummertech is off the scale
Trying to fix a "creek" noise without actually hearing it in person is next to impossible.
But I'll take a wild stab at it.
Check your front lower control arm bolts for being loose.
Old 11-01-2005, 03:36 AM
i got an alpine system in the truck thats loud but i hate my truck sounding like a piece of **** as i go down the street
