Old 08-13-2003, 02:07 PM
Capt Chuck Capt Chuck is offline
Capt Chuck is off the scale
Is there any lights (ie. PIAA) to replace the DLRs that will have more power. The size is the problem I am having with finding replacements. Thanks for all your help. Great site.
Chuck
captain C
captain C
Old 08-14-2003, 01:15 AM
H2Norcal H2Norcal is offline
H2Norcal is off the scale
Capt Chuck,
Hummer Solutions is the only company that I believe has a DRL replacement kit. It includes Cibie off-road/driving lamps which are 3x brighter than PIAA 520's (the bigger lamps) and fit nice. You can't even tell they have been changed out until you turn them on. Then you definitely notice.... These can easily suffice in place of putting lights on your grill guard.
The kit requires some wiring knowledge and you have to cut the backs of the DRL cups.
Here's a link: DRL Kit
Good luck.
Chuck
captain C
captain C
Old 08-13-2003, 03:00 PM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
Cappy:
There are several threads on this. PhilD and I have replaced the crappy H2 DRL's with 03 Lincoln Navigator foglight fixtures. They utilize a 9145 (45W) halogen bulb but can use a 9004 standard high beam bulb, or a blue xenon as Phil has used. It takes only minor modification to the air dam and replacing the bulb pigtail/wiring with a pigtail obtained from a salvage yard. Check out our threads on this and you will see/read all about it. There are also other threads using more expensive fixtures and more difficult installation procedures. Then you need either to jump the DRL's with the parking light relay or wire then to their own circuit/switch so that you can turn them on at night.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 08-13-2003, 09:09 PM
H2 007's Avatar
H2 007 H2 007 is offline
H2 007 is off the scale
I'm suprised that someone has not come out with a replacement set up for these. They have crome everything to no end, but not a replacement DRL housing?
This should be an easy aftermarket idea for someone to come up with.
2003 White Hummer H2
2008 H2 Graystone Metallic
