Old 12-10-2003, 12:04 AM
LoopSS LoopSS is offline
LoopSS is off the scale
Hi Folks,
Sounds crazy but I can not get headlights and
driving light (little ones in the bumber) to
stay on together. During the day the little on come on but a night automatic light sensor swithches to headlight. I want them both to be on. Or GM didn't think of that. Just one at the
time.
Help!! Is there any mods to keep them both on.
ALAN
SUNSET ORANGE
Old 12-10-2003, 12:14 AM
MAC MAC is offline
MAC is off the scale
King Solomon's secret map.
Old 12-10-2003, 12:11 AM
You need to run the jumper...
Details
Adam P. Smith
Mortgage Pros, Inc.
303-407-2405 p
303-407-2414 f
aps101374@yahoo.com
Old 12-11-2003, 01:37 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2Norcal:
Or this
http://www.hummersolutions.com/Merchant2/merchant.mv?Screen=PROD&Store_Code=HSC&Product_Cod e=HSC-0305-CIFCLR&Category_Code=L100<HR></BLOCKQUOTE>
This is the setup I went with, just don't have them installed yet. Right now I have the stock DRL's coming on with the headlights. Broke some legs off the stock DRL relay so that it does not come on in the daytime though.
Old 06-20-2009, 01:07 PM
HummerMann's Avatar
Default Re: Headlights and driving Light together ON ?
OK, I ran the jumper from this old post and now my headlights are on all the time, even in the day. I was hoping to be able to manually select all lights on with this jumper instead of it being automatic. Are there any other automatic headlight sensors than the one in the dash in front of the passenger seat? I'm going to go out and check my jumper wire again.
Hummer, like nothing else
Old 06-20-2009, 02:22 PM
BradO's Avatar
BradO BradO is offline
BradO is off the scale
The diagram is correct. On auto, only your DRL's should be on in the daytime and both on at night. Check your pin positions again. You should be able to check by manually switching between parking on and headlights on to make sure you've wired it correctly. Unless something is covering your light sensor (or of it's bad), you should be in good shape. Good luck. Thanks...
Old 06-21-2009, 04:33 PM
HummerJim's Avatar
I like that look. I opened the fuse cover and found the fuses in question. For those of us who are electrically challenged, when you say jumper - did you use a wire with alligator lips on both ends or solder the wire in and what gauge wire should you use? Could you just do this with alligator clips and a wire?
Old 06-22-2009, 01:34 PM
Guys, you need to learn to use the search button.
DRL
Check out the 3rd or 4th thread....
Old 12-11-2003, 10:35 AM
H2Norcal H2Norcal is offline
H2Norcal is off the scale
Or this
High Powered, Switched, DRL Replacement Kit
Old 12-10-2003, 01:17 AM
AL MOORE AL  MOORE is offline
AL  MOORE is off the scale
It is not much light, But I like the look. I went the switch route. Under the dash a switch will on or off the lights.
"Follow the white rabbit..." Morpheus 1999....... It is finished.
\"Follow the white rabbit...\" Morpheus 1999....... It is finished.
Hi Folks,
time.
ALAN
SUNSET ORANGE
Old 12-10-2003, 05:49 PM
argonaut argonaut is offline
argonaut is off the scale
yeah, the bottom ones were designed as DRLs. I do like the looks of having them on. Not sure what a jumper is, but that pic looks good. mac, you are a strange man with strange treasure maps...
