Old 05-14-2005, 07:00 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
Ok not hummer, but Can any one tell me if you have air being forced into the master cylinder when you press the brake pedal ( on a 98 Z71). Is there something wrong with the power assist or is it a master cylinder failure?
drmiles's Avatar
Old 05-14-2005, 10:12 PM
Jerry-
What makes you think that air is pushed into the master? The booster is connected to the master thru a push rod..
The isn't anyway for air to be forced into the master cylinder.
Can you give anymore details?
Want-08 Viper, 06 M5
Old 05-15-2005, 09:45 AM
HGW HGW is offline
HGW is off the scale
More details--if you had excess air in the brake system, you would have brake fade or nrake failure.
Did you bleed the brakes to determine if there is air in your system?
Brake fluid breaks down over time, creating some air in the system. Bleed and replace fluid.
Old 05-17-2005, 06:09 PM
drmiles's Avatar
Well its resolved,replaced the master cylinder,and now have rear brakes again. the Master cylinder was pumping air and fluid into the reservior windrhen the brake pedel was depressed. And there was no pressure at the rear wheel cylinders.
Thanks, for the help Problem resolved for $29.00
