Old 04-11-2006, 04:52 AM
Linegod Linegod is offline
Linegod is off the scale
Im not sure if I was asking at this point in time about a train horn to be mounted on a 2004 Hummer H2...If not do you know of a place on the web where I can find out where they are mounting these things? There isnt enough room under the hood..The horn is chrome and has three "Horns" attatched to a base with a seperate compressor tank measuring approx 8" wide by 18" long..The horns measure to the best of my memory about 18" across and 22" long I mean they are a monster. Would appreciate any help you can give.
Old 04-11-2006, 07:01 AM
WORKIN WORKIN is offline
WORKIN is off the scale
most mount to the roof rack track, with an adapter plate. and run the hose, and lines through the roof.
03 H2- polished stainless brush gaurds, front and rear. front and rooftop lighting, hard cargo carrier....
Old 04-11-2006, 07:13 PM
usmctopgun usmctopgun is offline
usmctopgun is off the scale
I went w/ these. They fit nicely under the hood of the H2.
Train Horns
Semper Fi,
Michael
Old 04-11-2006, 11:58 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
Train Horns
Darn those are nice.
Old 04-12-2006, 01:02 AM
twenty2's Avatar
twenty2 twenty2 is offline
i wish you could post a mpeg of you driving your rig and scaring some people at the bus stop.
Old 04-27-2006, 07:07 PM
I guess Ill try and look again for space under the hood because these are like the ones that I have...Train Horn I Bought From E-Bay
Old 04-27-2006, 07:10 PM
One last thing has anyone with the train horn experienced a break in the air hose? At the dealer in Hollywood Fla. They said that they dont install them anymore because the air hose breaks and then the compressor runs constantly and burns out...Soooo I thought of using copper tubing like they use on the back of refrigerators for ice machines...
Old 04-27-2006, 11:52 PM
Email this guy and he'll sell you some 1/2 air brake line that will work really well. Also, I do not suggest going w/ a kit from ebay. I went w/ a ViAir 480c Compressor, all 1/2" air line, and a 3 gallon tank along w/ the horns mentioned above. I also suggest going w/ a differnet solenoid to allow better airflow. Good Luck.
FASTBAG90@HOTMAIL.COM
Semper Fi,
Michael
Old 04-30-2006, 11:27 AM
Jeff B's Avatar
Jeff B Jeff B is offline
Jeff B is off the scale
I found these after I installed the Real Wheels horn.
http://www.hornblasters.com/
Old 04-30-2006, 07:45 PM
Search for "Train Horn" and "Air Horn". Dan bought those horns the the trumpets fit under his hood.
He also had some problems with the compressor and trumpets, but got things worked out and they're some loud sum-bishes.
Old 04-30-2006, 09:01 PM
When does RAAARR11 get some? That monster needs some.
Old 04-30-2006, 10:50 PM
mbdougl's Avatar
mbdougl mbdougl is offline
mbdougl is off the scale
Train horns are ghey! This is better -
http://www.jpcustoms.com/store/customer/product.php?pro...17178&cat=352&page=2
Old 05-01-2006, 01:05 AM
LMAO! DO you have this installed? pics installed?
Old 06-08-2006, 04:59 AM
Jeff B's Avatar
Default Re: Train Horn For H2
Here is my RealWheels Air Horn installed on the roof rack rails. It was pretty simple to route the air hose under the wiper cowl and up the exterior driver's side pillar trim.
Old 06-08-2006, 06:33 AM
Motohead's Avatar
Motohead Motohead is offline
I have the hornblasters kit with the 3 gallon tank I believe. I have a setup on my Dodge Ram also. I have never experienced a hose break problem and I am running 160psi. There is very little room under the H2 to install. The set I run is a 4 horn conductors special and they are big. Here is the set up on mine. If I go offroad and need to remove them 2 bolts and its removed. As far as being worried about the hose breaking and ruining the compressor and draining the battery, just wire it to an on/off switch. Mine is also wired so when the truck is off, there is no power to the compressor, and also an on off switch to disable it when its on if I want.
These puppies are loud, same one as in the hornblasters videos.
Old 10-23-2006, 05:53 AM
KrazyMedicRN's Avatar
KrazyMedicRN KrazyMedicRN is offline
KrazyMedicRN is on a distinguished road
I was skimming thru the topics and ran across your post I live across the bay in North Pinellas... Can you tell me what that set up cost and who installed it
Thanks in Advance
Rich
Picture of my 2005 H2 YELLOW SUT
http://www.myspace.com/krazymedicrn
Old 10-23-2006, 06:23 AM
MDimitri's Avatar
MDimitri MDimitri is offline
Cool Re: Train Horn For H2
I picked up a great set of triple horns for my rig from Siege Engineering, 3 gallon 250psi tank, 1/2 inch lines, extreme pressure release valve, monster 40mm compressor, relays, switch's, fittings and more for $600.00. Running larger lines will allow you to move alot more air and get a bigger blast from your horns without bringing the heat and wrecking your compressor. This is how a train horn is supposed to sound....CRANK UP YOUR PC SPEAKERS AND LISTEN...
http://www.siegeengine.com/auctions/horn/horn.mpg
http://cgi.ebay.com/Train-Horn-Triple-Air-Horns-GOLD-PLATE_W0QQitemZ130039593546QQihZ003QQcategoryZ1493 2QQtcZphotoQQcmdZViewItem
Old 10-23-2006, 05:54 PM
Motohead's Avatar
Medic, I sent you a pm. I installed the system myself.
