Old 02-10-2006, 01:05 AM
H3Eric H3Eric is offline
H3Eric is off the scale
Does anybody know how I control the volume of the chime. I can almost not hear anymore and I don't know what happened. I did install a 6cd radio but for many weeks everything was fine. There must be a way to control the volume
Any suggestions??
Any suggestions??
Old 02-10-2006, 02:10 PM
HumbleAg HumbleAg is offline
HumbleAg is off the scale
The dealer's techs can adjust the chime volume (also controls onstar volume), I believe using the programming tool. This controls the level of the stereo volume into the amp. When I had my radio replaced they had it too loud and the chimes blasted me out.
You can adjust the chime volume between two levels, hold down the 6 button until the display changes.
Old 02-10-2006, 02:37 PM
humdoug's Avatar
humdoug humdoug is offline
humdoug is an unknown quantity at this point
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HumbleAg:
You can adjust the chime volume between two levels, hold down the 6 button until the display changes. </div></BLOCKQUOTE>
The standard setting is NORMAL and if thats to loud you're in trouble since the only other level is LOUD.
Old 02-11-2006, 12:39 PM
Thanks for the replies. The chien was on normal vs. Loud. And I need to got to the dealer to make it even louder.
Thanks for your help.
