Old 11-27-2003, 12:26 PM
sabjr sabjr is offline
sabjr is off the scale
My H2 door panels are so squeaky! I ran into another H2 owner in a parking lot yesterday and the first thing he asked me was "do your door panels squeak?" Are they all like this? Can it be fixed? Help please!! Thanks
Old 11-27-2003, 12:45 PM
austoak austoak is offline
austoak is off the scale
I HAVE THE SAME PROBLEM WITH MY DRIVERS SIDE PASSENGER DOOR. WHILE DRIVING IF I REACH BACK AND PULL UP ON THE DOOR HANDLE IT SEEMS TO GO AWAY FOR AWHILE. BUT IF I PUT THE WINDOW DOWN ABOUT AN INCH IT COMPLETELY GOES AWAY UNTIL I PUT THE WINDOW BACK UP. SOME ON THIS FORUM HAVE SAID THAT THE WINDOW TRACKS NEED TO BE ADJUSTED. I HAVE NOT HAD TIME TO BRING IT BACK TO DEALER, SINCE I LIVE AN HOUR AND A HALF FROM THE DEALER. BUT WHEN IT GETS IT'S NEXT OIL CHANGE IT WILL BE THE FIRST THING THEY LOOK AT. GOOD LUCK !!
Old 11-27-2003, 01:54 PM
Jigga Jigga is offline
Jigga is off the scale
i had the same problem in the same door. What i did was get a adhesive pad and cut a little sqaure out of it. I used a screwdriver to pry up the pannel just enough the stick the pad on the door and pushed the pannel back down on it. That should help keep the door from squeaking. It has worked for me so far.
2003 Pewter H2 with Adventure Package, 20% tinted front windows, K&N aircharger filter kit, 3 screen DVD and Playstation 2 system. Soon to come: 37" MT/R's, Warn winch, XM and subwoofers.
Sig lines are overrated.
Old 11-27-2003, 02:03 PM
Ed G.'s Avatar
Ed G. Ed G. is offline
Ed G. is off the scale
I did the same as Jigga did, only I used the "soft side" of adhesive velcro. I put a piece at the top right corner on the drivers side and top left corner of the pass. side.
Ed
2008 H3 Alpha - Boulder Gray
Old 11-27-2003, 02:10 PM
TBarrow TBarrow is offline
TBarrow is off the scale
Go to any craft store and you can get craft felt where one side has an adhesive back. I have used it for years to quiet squeaks and rattles.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, B&B Headers and exhaust, 2-7" screens in headrests with DVD player and TV Tuner.
Old 11-27-2003, 03:21 PM
MAC MAC is offline
MAC is off the scale
I am almost embarrassed to say I have no squeak and no rattle anywhere in my Hummer, 20K miles in 14 month. But people need to know not all Hummers have this problem.
Old 11-28-2003, 01:19 AM
cmb31078 cmb31078 is offline
cmb31078 is off the scale
Only rattle I have after 5000 miles is the jack because I took it out once and did not tighten it down all the way... On my to do list
Craig
04 Pewter H2- Lux,nav, air suspension
Craig
