Old 10-15-2003, 11:17 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
When should I rotate my tires. I have 12,000 miles. Let me know thanks
Albie's Avatar
Old 10-16-2003, 02:26 AM
Circuitguy
I think it should be every 5000 miles but I could be wrong. I have 12K on mine, I think its about time for me too! BIG-C
White 03-H2-LUX
</a>
Old 10-16-2003, 04:27 AM
crash crash is offline
crash is off the scale
Every 6,000 miles
certified H2 tech.
certified H2 tech. troll
Old 10-16-2003, 12:50 PM
Albie's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by PhilD:
According to the H2 Owners Manual the tires should be rotated every 7500 miles. I personally like to rotate the tires every 5000, and usually at 3000 for the first rotation.
Crash, as a Certified H2 tech are you saying that the official line is every 6000?<HR></BLOCKQUOTE>
Phil D thought you fell off the edge off the earth. Thanks Guys Going to do it this weekend. Very over do.
Old 10-16-2003, 03:00 PM
DURAMAX TIM is off the scale
I thought they rotated everytime u drive it?
Or do u guys leave it parked and have to rotate to keep from flat spotting?
I'd love to do some diving but broke 3 ribs in late May and middle of June broke another that was cracked from May.
Now that I'm healed, I'm toooo busy.
98 ZR-2 Blazer
Ex H2&3 owner
Old 10-17-2003, 01:25 AM
unaslob unaslob is offline
unaslob is off the scale
not rotating tires with an aggressive tread about every 5000 miles can cause excessive tire roar and tire damage. happened to a jeep sarhara that i used to have. had to buy all new tires... ther were ruined with only like 15000 miles on them. una
Old 10-17-2003, 09:03 PM
Chewy Chewy is offline
Chewy is off the scale
Every other oil change should be just right.
Old 10-17-2003, 09:23 PM
Do you rotate the tires along with the SPARE??????
"A Picture Is Worth A Thousand Words."
Old 10-17-2003, 10:14 PM
I simply choose to have the tires rotated every time I get the oil changed. It just easier for me to keep up with it and I change the oil every 5-7K miles.
I have rotated the spare in the past but haven't on the H2. The logic in the past was that I was going to go with a different tire than I had so just rotating the spare in made sense. If you have the spare tire carrier, a worn tire just doesn't look as good though.
Old 10-18-2003, 12:17 AM
i rotate with oil changes.... it cost 5 extra bucks... I do not rotate the spare into the mix. reason being, is that when it is time to purchase new tires... I only buy three, put the spare on and take the best other one and use that as the spare...why not...it's a spare... did you ever try to lift those tires... those guys who do it for 5 bucks earn every penny. una
