Old 05-07-2003, 12:45 AM
hoot hoot is offline
hoot is off the scale
Hello H2 lovers....
I have a 2001 2500HD GMC Duramax Diesel pickup with chromed H2 wheels. Does anybody know the load specs on these wheels. I realize the H2 is a 8600 GVW vehicle. I would think the wheels are rated around 2200 lbs??
Hello H2 lovers....
Old 05-07-2003, 08:26 AM
DURAMAX TIM is off the scale
I'm not sure on the rating either.
Just curious on the size tires u have on it.
I'm going to put on stock H2 rims and would like to go BFG 285/70R17 tires (I have 285/75R16 BFG on it now).
Is the backspacing OK?
BTW I think the H2 has the 6000# rear axle (couldn't find specs on web) if so the rims are rated at least 3000# each.
The front axle is 4000# rated.
98 ZR-2 Blazer
Ex H2&3 owner
Old 05-07-2003, 09:38 AM
I have Pro-Comp 33/25.5-R17's on them. Same as 305/70-R17's I think.
Fit is great. Bars cranked about 5 turns. No lift.
These are cast wheels so I don't think they are rated that high but I could be wrong.
The 5.5" backspacing is the best part. It puts the tires right where we want them.
Old 05-07-2003, 12:51 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR> I have Pro-Comp 33/25.5-R17's on them. Same as 305/70-R17's I think.
<HR></BLOCKQUOTE>
Do u mean 33/12.5-R17 or are the tires 25.5" wide?
What rating are the tires C or D ?
I need D rating for the weight capacity.
98 ZR-2 Blazer
Ex H2&3 owner
Old 05-07-2003, 02:58 PM
Sorry, I meant 33/12.5-R17
Yes they are "D" 8 ply tires.
Old 05-07-2003, 03:21 PM
I hate to keep bugging u BUT did u have to pull the inner fenders back so tires wouldn't rub?
After the 5 turns in front bars did it change alignment?
98 ZR-2 Blazer
Ex H2&3 owner
Old 05-07-2003, 06:14 PM
No problem.
All I did is what I said. Nothing more. 5 turns.
It does change th ealignment slightly. Mines getting one. just in case. Drives straight.
Old 05-17-2003, 10:28 AM
The door GVW sticker says 5000# rear axle so the rims have to be atleast 2500# rating or more.
98 ZR-2 Blazer
Ex H2&3 owner
