Old 11-03-2005, 05:32 PM
NJ H2's Avatar
NJ H2 NJ H2 is offline
If you have a dual washer system (front and back) then you need the bypass kit. The kit pulls washer fluid directly from the washer fluid tank and into the HotShot. My guess is there is not enough suction with a dual washer system to pull the water.
Old 11-03-2005, 07:33 PM
Mr. I - Man's Avatar
No what is the Auto mode supposed to do???
Old 11-03-2005, 08:41 PM
dochummer's Avatar
push and hold the button for 3 seconds. then release. It will then warm the water and shoot it at the windshield every 30 seconds. If it tries, and fails...the button will flash repeatedly...means you're not getting enough fluid through the system...
'03 H2
Old 11-03-2005, 08:50 PM
Cool it works
