Old 08-26-2005, 10:33 AM
Oh look, here's a plug that's not doing anything. Just remove it and mount the camera there! </div></BLOCKQUOTE>
Old 08-26-2005, 10:35 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Dick Renaud:
Plug the hole and use the marker light cam </div></BLOCKQUOTE>Too much of the view is blocked by the spare for me. If I am going to stick a camera back there I want it to be able to make it easy to back to a trailer.
Old 08-26-2005, 10:39 AM
So, I am go to have a piece of metal made to fill the gap just above the hitch (between your current postion and the hitch) and mount the camera in it. </div></BLOCKQUOTE>Make 2...? </div></BLOCKQUOTE>Not before Moab. I am on a "need to have done" basis right now. Some of my little projects are getting put on hold because I need to put my truck back together and I need to replace the tie rods.
Remember a 1 hour project is likely to take a week for me these days.
Old 08-26-2005, 11:31 AM
kdio kdio is offline
kdio is off the scale
I was thinking of mounting a camera on the rear tire carrier. If you mount the camera in the center of the rim (depending on what style rims you have) you can modify the cap so that the camera sticks out of it. I would think this would be the best location for visibility. I would run the wires to the camera on the back of the tire carrrier, like the SUT tire carrier runs the lights for the license plate.
Old 08-26-2005, 01:32 PM
Fubar's Avatar
Fubar Fubar is offline
<A HREF="http://www.gstyle4u.com/.sc/ms/dd/1064352504935431/9/nc--^202http^3A^2F^2Felcova^2Ecom^2F6^2Fubb^2Ex^3Fa^3D tpc^26s^3D2826088551^26f^3D5106011751^26m^3D577609 2955/Audio%20%26%20Video/98/H2CAM%20WITH%20MONITOR%20^2F%2003-04%20HUMMER%20H2" TARGET=_blank>http://www.gstyle4u.com/.sc/ms/dd/1064352504935431/9/
nc...003-04%20HUMMER%20H2</A> </div></BLOCKQUOTE>
Sadly the marker light cam's are not worth a **** especially with an over size tire. With the stock tire on the carrier all you see is the back and top of the tire then out to infinity. It would be worse with a 37inch tire in place. No amount of adjustment of the marker light cam will allow you to see what is below the tire i.e the hitch if you're backing up a trailer or a childs bike parked just behind the tire. It's useless in my opinion.
H2Finally have you considered a hitch cam? It doesn't solve your problem of the hole in your bummper if you remeove the cam that is there unless you leave the cam where it is and simply unhook it or run both video feeds to your display and switch them to whichever view you want to see. I'm not sure how exactly that could be done but I'm certain that it is possible.
Old 08-26-2005, 01:55 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fubar00:
H2Finally have you considered a hitch cam? It doesn't solve your problem of the hole in your bummper if you remeove the cam that is there unless you leave the cam where it is and simply unhook it or run both video feeds to your display and switch them to whichever view you want to see. I'm not sure how exactly that could be done but I'm certain that it is possible. </div></BLOCKQUOTE>Simple video switcher from radio shack
Old 08-26-2005, 02:17 PM
H2F, I'll send you my perfect bumper so you won't have to worry about patching the hole. Just send me yours, with the camera and wires still attached. Then you don't need to worry about the new mounting location, either. We'll kill both birds at once.
Old 08-26-2005, 02:40 PM
H2Finally's Avatar
H2F, I'll send you my perfect bumper so you won't have to worry about patching the hole. Just send me yours, with the camera and wires still attached. Then you don't need to worry about the new mounting location, either. We'll kill both birds at once. </div></BLOCKQUOTE>Only if the Lingenfelter is attached to it!!
Fubar, mine was originally installed in the hitch location, but it seemed that I test the departure angle quite a bit. At one offroad event, I dragged the hitch over a (BIG) rock, and the hitch cam mount was destroyed..
Kdio, I'll consider your suggestion!
Can BLING Get You Home?
Old 08-27-2005, 12:57 AM
Mr. Jeep Mr. Jeep is offline
Mr. Jeep is off the scale
Upgraded my 35" spare to 37"MT/R (thanks partsguy! ). But now HALF of my backup camera is covered by the tire!! I can't relocate the camera cause it's gonna leave a big hole in my bumper! Worse, if I use the soft tire cover, it covers 3/4 of the camera!!
WHAT TO DO??? </div></BLOCKQUOTE>
______________________________________________
You think someone would have thought of this dilemna before you changed everything??!!
You know, some people only have one usable eye and they get along pretty well! Atleast you have a partial camera! We have to get out of the f**kn thing and spot each other!
y\'all are fools
Old 08-27-2005, 06:01 PM
Dick Renaud's Avatar
Dick Renaud Dick Renaud is offline
Dick Renaud is off the scale
Another option for the camera
http://www.mitocorp.com/flash/backup...rame_specs.htm
Old 08-28-2005, 08:04 AM
wilfred wilfred is offline
wilfred is off the scale
Kdio, I'll consider your suggestion! </div></BLOCKQUOTE>
H2Finally, i don't know what kind of hitch cam did you have but i can take some pics of mine (homemade ) tomorrow. I don't think mine will affect the departure angle and the cap itself was like $10-$15 @ autozone, not including the camera of course.
Old 08-28-2005, 04:36 PM
Here's mine, the cover was chrome but i painted it.
Old 08-28-2005, 04:41 PM
another shot
