Old 09-15-2005, 10:57 PM
ASJ ASJ is offline
ASJ is off the scale
So I went to my dealer to have the
rattling sound inespected in my hummer
because everytime I
go uphill or press on the gas pedal to
2500 rpm and hear my engine sound stressed
out (some fluttering near the intake,
light rattling).
They were able to reproduce the same sound
by pressing the gas pedal and brake at the
same time up to 2500 rpm on my H3. They reproduced the same rattling on a few other
H3s in their dealership. They contacted Hummer about the issue, and Hummer responded by saying that this is a non-issue right now until they
figure what to do. The dealer said it sounds
like the timing chain. Probably because the
Hummer is underpowered to lug around that
weight. Anyway, anyone else have this issue?
ASJ ASJ is offline
because everytime I
light rattling).
Old 09-15-2005, 11:08 PM
H3ProspectKy's Avatar
H3ProspectKy H3ProspectKy is offline
H3ProspectKy is off the scale
No, I don't have that problem with mine. I don't think it is "all HUMMERS".
Old 09-15-2005, 11:13 PM
ASJ ASJ is offline
I mean it's not THAT noisy, but you
can hear the engine stressed out especially
when you go uphill.
Rachmunas4Life Rachmunas4Life is offline
Rachmunas4Life is off the scale
Man I hope I won't have the same problem when I'm going up the mountain roads of Colorado..
Old 09-16-2005, 01:02 AM
H3 Hummer's Avatar
H3 Hummer is off the scale
I live on a 12% grade and I don't have this issue. When going over Snoqualmie Pass here I have to push down the gas but drive in the fast lane just fine.
Old 09-16-2005, 01:10 AM
H3OH H3OH is offline
H3OH is off the scale
WTF
All this talk about the "rattling" noises and issues is starting some concern on my end. I guess I should turn off the Monsoon for a while and see what in the sam hell is going on.
I live in Texas, and hills are all around...
\"In the poker game of life, women are the rake man. They are the f$#@%n\' rake.\"
__________________________________________________ _____________________
\'06 H3 - Birch White, Auto, Lux Pack (with Homelink), Chrome Pack (with Crossbows), Chrom
Old 09-16-2005, 02:50 AM
TexasRTR78 TexasRTR78 is offline
TexasRTR78 is off the scale
LOL....same here...I never have the stereo off while driving...guess I should do the same to see if I hear any "rattling" noises...COURSE, I will just have to punch it to produce the stress...I live in Texas, too, but no hills here, just flat land and lots of caliche dust!
Old 09-16-2005, 07:51 AM
I have driven with the monsoon off to try and hear some of these strange noises the happen "on all" Hummers, and so far, no noise.
I'm 57, and I have learned throughout my many years, (last 14 in the car industry), never to believe what 80 percent of dealership service people say.
If they are not competent enough to fix a problem, there normal response is GM (or Ford, or whomever), cannot fix the problem and it is normal.
I cannot believe that someone at GM said that this is normal and they are not doing anything about it...IF it is as large of a problem as the dealer implies.
As an employee of GM, I can tell you, they have a quality push on that is driving many crazy.
As for the timing change, it is set to a particular specification, and if it rattled on the H3, it would rattle on the Colorado/Canyon, since it is the identical engine. Torque is torque to an engine.
I would recommend that the dealer pull out his chassis ears (a require tool), and drive around till he locates the problem, and then either confirms it is the timing chain or some other source.
Old 09-16-2005, 10:28 AM
It makes noise, it will sound like the engine is going to pop out of it if your not used to trucks. It has plenty of power just winds up a bit to use it. Go buy a big towncar so yo won't hear any noise. this is what happens when car owners buy off road vehicles. I saw it so many times it makes me sick.
Old 09-16-2005, 11:04 AM
bparker's Avatar
bparker bparker is offline
If all hummers do this then mine must suck because mine doesnt rattle. I guess I need to take mine back to the dealership and bitch to them about mine not rattling enough!
http://www.tahoeforum.com
http://www.motoforum.com
Old 09-16-2005, 11:34 AM
1COOLH3 1COOLH3 is offline
1COOLH3 is off the scale
Here is a new Service Bulletin for the problem and the fix:
Buzz or Rattle Noise - keywords 3.5L heat L52 nut RPM shield #PIT3475B - (Sep 15, 2005)
Buzz or Rattle Noise While Driving Under Load from the Exhaust
2004-2006 Chevrolet Colorado Pick Up
2004-2006 GMC Canyon Pick Up
2006 Hummer H3
Condition/Concern:
Buzz noise from the engine compartment or exhaust area. This may occur while the engine is under load or driving with the RPMs between 2200 and 2800 under load. The noise may also sound like it is coming from the air cleaner area. This concern only applies to the L52 3.5L engine.
Recommendation/Instructions:
Secure the nut above the O2 sensor.
Secure the nut on the #1 exhaust tube.
Old 09-16-2005, 01:05 PM
with the H2 it was the skid plate and exhaust rattleing. First year stuff it happens
Old 09-16-2005, 03:50 PM
jp's-h3 jp's-h3 is offline
I have the 5-spd. no such problem w/ mine
Old 09-16-2005, 04:31 PM
Marc H3 Marc H3 is offline
Marc H3 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ASJ:
because everytime I go uphill or press on the gas pedal to
light rattling).
… Probably because the Hummer is underpowered to lug around that weight. </div></BLOCKQUOTE><span class="ev_code_BLUE">FYI: The 4 Door </span><span class="ev_code_RED">*</span><span class="ev_code_blue">Colorado/ Canyon weighs approx 5,000 lbs and is at least 240 lbs more weight than the H3. If this was a vastly "underpowered" engine the then it surely would be a larger complaint with the other 4 door trucks that the I-5 goes in.
BTW: VERY FEW are complaining about lack of power on the 4 door Colorado/ Canyon. </span>
<span class="ev_code_red">*4 DR 4x4 weighs in at 5,000 </span>
Old 09-18-2005, 11:14 AM
ASJ ASJ is offline
Where do you get the Service Bulletins?
Is it available online?
Old 09-18-2005, 02:06 PM
HummerJim's Avatar
It sounds like a truck, as it should. 22,854 miles and the only thing I found you don't want to do with the engine is mash the pedal to the floor from a static position. If you do that, it will whine and grunt and talk to you. Otherwise no problems, and I probably have more mountain time in my H3 than anyone and don't even notice it downshifting and find it quieter than the wife's Xterra. If anything, I find the engine noises music to my ears, when the Monsoon isn't on!
Old 09-25-2005, 06:47 AM
Gun Oil Gun Oil is offline
Gun Oil is off the scale
I experienced a similar noise this week while renting an H3 from Budget at the Denver Airport.
Scared the crap out of me, as it would manifest after driving for about 20+ minutes at highway speed. It comes on as the throttle position is increased.
Sounds like the "Flubber" car.....REAL hard to describe.
The weirdest thing about it is it goes away if you stop and idle for a couple of minutes.....
Me thinks.....a potential drive train issue... 3
Although no loss of power......just a real lame ass noise!
Old 09-26-2005, 12:34 AM
dukein's Avatar
dukein dukein is offline
dukein is off the scale
I have a Basic Pkg with 1822mi on it but haven't heard any rattling noise (knock on wood). I went up and down the Sierra Nevada Mountains/Lake Tahoe area taking the toughest climb (hwy#50 & Kingsbury Grade) over the weekend but did not noticed any, perhaps my stereo was too loud.
2006 H3 Base Stockers
Old 09-26-2005, 02:43 AM
ASJ ASJ is offline
Drivetrain issue? What does that mean?
What is drivetrain? Should I trade in
my H3 if that is the case?
