01-15-2006, 03:14 PM
I know for the stock wheels the torque is 140ft/lbs, will that change with my larger wheel/tire combo? Or will it always be the same?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
01-15-2006, 03:50 PM
Same always.
01-15-2006, 03:55 PM
Should be the same because the torque value is for the size and grade of steel the wheel stud and lug nut are made of.
If the wheels are of a "soft" material might be best to double check the torque around a couple hundred miles to be sure they stay the same as what you set them to.
01-15-2006, 08:29 PM
Thanks guys, I just didn't want to end up over torque them.
01-16-2006, 12:10 PM
stomp.....check with factory...my boyd cottington hot rods are torqued to 90 flbs....so thats a sizable diff from 140....i always questioned that 140 flbs on stock rims anyway...seems way to high opinn.......soft...
01-16-2006, 02:47 PM
I agree, most alloy wheels are torqued to 85-95 lb-ft. 140 seems like over kill! Check with the wheel manufacturer to be sure.
Mike S
Mike S
03 Pewter H2
01-16-2006, 03:19 PM
Dealer said keep them at 140!
01-17-2006, 12:26 PM
C'mon, nobody torques those. Just hit 'em with the impact gun!
01-17-2006, 02:19 PM
impact gun is just wrong,,,why spend all that money to take a chance on screwing up a rotor or rim......i check torque about every 3 months,and you would be amazed what you find out of torque...j/m/o/p.......soft...
01-17-2006, 02:47 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">C'mon, nobody torques those. Just hit 'em with the impact gun!
05 Black SUT - XtremeFlow
------------------------------------ </div></BLOCKQUOTE>
Sometimes when your in th field and try to change a wheel because of a broken bead or flat. The lug nuts are impossible to get off. So I hand tighten mine with a long breaker bar I bought from Low's.
01-17-2006, 02:56 PM
Funny thing, 2003 owners manual shows it to be 140 lb-ft (190 N-m) on page 6-68 and the 2003 service manual shows it at 125 lb-ft (170 N-m) on page 3-56.
I've been using 135 lb-ft on mine for the seven tire rotations I've done so far without any problems, that I know of
01-17-2006, 03:42 PM
damn that is wacky. Wonder if a tech can weigh in?
01-17-2006, 04:07 PM
01-17-2006, 06:55 PM
Found a site that list most vehicles and it has 140 ft-lb for the H1 and the H2.
Discount Tire Site
