Old 08-09-2003, 10:49 PM
H2ummer H2ummer is offline
H2ummer is an unknown quantity at this point
Has anyone done the TSB for fixing the Auto Volume on the Radio either themseleves or at the dealer? Just wondering if it acutally fixed it, before I go through all the trouble of tearing the console apart.
Thanks,
03 H2 Pewter W/Lux, Delphia XM Radio
03 H2 Pewter W/Lux, with 05 Navigation Radio and XM added. (Sold)
07 H3 Slate Blue W/Lux, Off-Road, NAV, Sunroof, XM, Tow, Auto (Sold)
08 H2 White W/Lux, NAV, Air Sup.
Thanks,
Old 08-09-2003, 11:34 PM
I have come to the conclusion that the auto volume feature is non-existent. One my first H2 the techs went so far as to replace the radio with no results. The auto volume worked perfectly in my Tahoe.
One thing that was cool on my first H2 was that when the radio was in Spacious mode and I hit the auto volume button on then off and back to on it would boost the bass in the system. My new H2 doesn't do it though.
Old 08-09-2003, 11:52 PM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
Two radios later and auto-vol still does not work ... they still cannot get me a radio that does not shut off when you press the button to adjust the bass, etc. when in CD mode, though ... they have asked me to wait for the 2004's, and they will exchange my 2003 radio for a 2004. Supposedly a new resource is making the radios for 2004 .... they told me that only the speakers are Bose and the radios are GM ... go figure ?
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 08-10-2003, 11:05 AM
TJ TJ is offline
TJ is off the scale
Three radios and one amp later, mine still doesn't work right either. I also had the auto volume TSB "fix" done, but it has made absolutely no difference. The auto volume in our Silverado works great, as did the auto volume in all the GM rentals I've had when my H2 has been in the shop (Tahoe mostly, but also Yukon and Suburban). Don't know why the H2 radios should be any different.
I am also still having problems with the CD player "repeat" button and they can't seem to find the problem and/or be able to fix it...when repeat button is pressed mid to end song, about half the time it will jump tracks and repeat an entirely different track for you. This last time they said "unable to reproduce", talked with TAC and declared it "case closed". Case is NOT closed though until it works like it should. I am going to schedule to take it back in again and have the technician sit there with me and WATCH it happen. This is the same thing that happened with our "Service Air Suspension". At first they were "unable to reproduce", just another "figment of my imagination" I suppose, so no fixes done. Finally we DROVE it in when the "Service Air Suspension" warning was on the display (luckily we were not too far from the dealer at the time). Brought the technician out to see it with his own eyes, and guess what...miraculously they DID find a problem that time that needed repairing (turned out to be the compressor).
Old 08-10-2003, 11:42 AM
Seems that the radios are a problem .... I have another new problem with my latest radio which I just learned about yesterday ... I took a longer trip in the truck yesterday that usual and the radio started to just shut off and on again after a minute or so, then off, then on again ... also the steering wheel controls for the radio stopped working as well as those on the radio ... the radio was very hot to touch (the digital screen was hot) and I noticed that the digital screen on the cooling/heating system controls was hot also. Again, it seems like it was over heating. Later on today I will try the radio again, when I go out ... it just takes time to keep taking the truck to the dealer 40 miles away ...
Anyone had this problem with their radio, as this is a this new problem for me ?
Best,
Michael
Pewter Hummer H2
Northern California
Michael
Pewter Hummer H2
Northern California
Old 08-11-2003, 02:14 AM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
My auto volume does not work either, but after reading about everyone's experiences with the repair, I think I will just forget about trying to get it fixed. The steering wheel buttons are convenient enough.
Old 08-12-2003, 11:24 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
H2ummer:
Search for Klaus's postings as I believe he has posted the TSB for the auto volume, if not see your dealer.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 08-12-2003, 11:59 AM
Unfortunately, the TSB for the Auto Volume does not work, at least my dealer has done plenty of the wire switching, but not one has worked. I took my H2 in yesterday as the radio stopped working completely (the second radio in my H2) and the Service Tech told me that the only consistent problem with the H2 and all of the GM vehicles using the same radio that we have is just that -- "THE RADIO" ... the same radio is used in the GM trucks, Buicks, Oldsmobiles, Chevrolets, and the like ....
Michael
Pewter Hummer H2
Northern California
Michael
Pewter Hummer H2
Northern California
Old 08-12-2003, 05:48 PM
TJ TJ is offline
TJ is off the scale
I agree, the TSB for the auto volume "fix" does NOT work...just had that "fix" done and it has made absolutely NO difference. My radio/CD player quit working altogether, speakers used to go out, and also used to jump radio stations all on its own, but hasn't done it again since the first or second replacement...I've had so many, I can't remember which
I'll check on that hot-to-touch and steering wheel control functionability and let you know once I get mine back...
Old 08-12-2003, 08:10 PM
DVJ DVJ is offline
DVJ is off the scale
Ah..... well you have all confirmed what I thought, the auto volume is indeed non-existent in my vehicle which is just 4-weeks old. I'd prefer to just leave the radio alone, but I will talk to the dealer about it just in case they plan a roll of defective units. Don't be too shocked if the speakers are not Bose, but only branded as such. It might just be a licensing play.
dvj
Old 08-13-2003, 08:35 PM
HummerN23 HummerN23 is offline
HummerN23 is off the scale
Before I had the TSB applied, pressing the auto vol button had no effect. For about a week or so after the TSB was applied, I didn't detect any difference. Then one day while sitting at a light, I pressed the autovol button a few times. Voila, when the volume was set low, turning on the autovol feature made the volume go up significantly. This is repeatable. Strange but true.
Old 08-15-2003, 02:32 AM
I just had my front speakers swapped out for a set of MB Quart RSC 216 and the difference in sound is incredible!! I was very disappointed to find that the speakers that came out were made of cheap cardboard.
I'm going to wait until the new radio comes out on the 2004 and then push for a replacement.
Old 08-15-2003, 03:10 AM
Just curious ... were the speakers that came out Bose ?
Michael
Pewter Hummer H2
Northern California
Michael
Pewter Hummer H2
Northern California
Old 08-15-2003, 02:10 PM
Albie's Avatar
Albie Albie is offline
Albie is off the scale
as some of you may or may not know I haven't seen or been in my truck for 3 weeks. Whats the auto volume do?
Old 08-15-2003, 04:50 PM
Hummer Man is off the scale
AUTO VOLUME is a feature that detects a 10% plus increase in volume and deamplifies it back to normal. Typically it "quiets" some of the commercials.
Old 08-15-2003, 05:02 PM
TJ TJ is offline
TJ is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Whats the auto volume do?<HR></BLOCKQUOTE>
The auto volume doesn't do anything, and therein lies the problem...
Theoretically, it's supposed to monitor the noise level inside the vehicle and adjust the volume level for you automatically. Push the "AUTO VOL" button until "AVOL ON" shows on the display, then turn up your radio or CD player while you're on the highway. When you get off the highway, it's supposed to detect the decrease in the noise level, so it's supposed to automatically decrease the volume so you don't blast your ears out...that's what it's supposed to do in theory, anyway.
Old 08-15-2003, 05:17 PM
TJ TJ is offline
TJ is off the scale
Sorry, I guess I made that about as clear as mud, huh? The auto volume is supposed to be able to monitor the noise level and automatically adjust the volume level up and down so the volume will always sound the same to you...so stop light, to highway, to stop light again, the volume level "should" sound the same to you (unless you turn it back up, of course )
