Old 10-11-2003, 12:45 AM
Zing's Avatar
Zing Zing is offline
Zing is off the scale
I just got u-steps and thought hard about where to put them when not in use. You can actually fit them under the back seat on the drivers side if you stack them right and they fit perfectly and sung. I'm kinda happy about this because now I don't have to drag them into my house or leave them rattling around in the back of the H2 offroad.
H2 '04 Black
Zing's Avatar
H2 '04 Black
Old 10-11-2003, 12:48 AM
NCHummerman NCHummerman is offline
NCHummerman is off the scale
Great idea .... Hey, does anyone have instructions on how to take them off ???? Do I need special tools ??? Thanks,
Michael
Pewter Hummer H2
Northern California
www.zootsuitstore.com
Michael
Pewter Hummer H2
Northern California
Old 10-11-2003, 02:56 PM
H2 Daddy H2 Daddy is offline
H2 Daddy is off the scale
Take out the retaining clip and unscrew the bolt. They then slide right off. It takes about 30 seconds per step to take them off.
Old 10-11-2003, 03:28 PM
Thank you H2 DADDY .... how about putting them back on ? Do they have to go in the same place that I take them off from ??? Should I label them ???
Thanks again,
Michael
Pewter Hummer H2
Northern California
Michael
Pewter Hummer H2
Northern California
Old 10-12-2003, 12:59 AM
argonaut argonaut is offline
argonaut is off the scale
Actually the easiest way is to use the allen wrench that came with the steps (it should be in the bag with the airhose). I tried loosening them by hand the first tim e, but they were on too tight to budge. It doesn't matter where you put them on, they are all the same
'03 H2 Sunset Orange No mods
'03 BMW M3 Convertible
'02 BMW M5
Old 10-12-2003, 12:54 PM
Mine doesn't have allen wrench bolts, just a big knob on one end of the bolts. They are not location specific. I have found the easiest way to get them back on is to lie on your back and put your head under the truck. This way you can see both pins on the steps and both holes on the truck's mounting brackets.
Old 10-12-2003, 01:49 PM
TBarrow TBarrow is offline
TBarrow is off the scale
The hole in the center of the Knob houses the allen head socket. At the house I use my air ratchet the allen adapter to remove quickly.
Black H2 Adventure Series + Luxury, AirForce One intake, Throttle Body Bypass, Gobi Rack w/2" Brackets & 4 PIAA 580 Lights, Xenarc HID, Alcoa Wheels, Goodyear 37x12.50x17 MT/R, Warn 9.5Ti Thermometric Winch, DiabloSport programmer,160 Degree T-Stat, 2-7" screens in headrests with DVD player and TV Tuner.
