10-09-2005, 01:47 AM
Sounds good, will this be available on H2 in 07????
The 6.2L engine of the Yukon Denali is all-new, with advanced technologies and lightweight materials – including variable valve timing and an aluminum cylinder block – contributing to the vehicle’s uncompromising performance. It produces 380 horsepower (283 kw)* and 415 lb.-ft. of torque (564 Nm).*
The engines are backed by proven Hydra-Matic electronically controlled automatic transmissions, including a new 6L80 six-speed that is matched with the 6.2L engine.
The six-speed automatic has a wide, 6.04:1 overall ratio – including two overdrive gears – that helps deliver an excellent balance of performance and fuel economy. Also, the 6L80 has a “tap up/tap down” capability that allows the driver to manually select upshifts and downshifts with a button on the column shifter.
10-09-2005, 01:56 AM
The H2 better get those upgrades.
10-10-2005, 12:47 AM
I like the "Fuel economy" part.!!
2006 H2 SUT Fusion Orange LE
10-10-2005, 10:00 PM
Anyone have pics of the new Denali??? Or know when they are supposed to be released?
10-10-2005, 10:11 PM
2003 Hummer H2 LUX...sold
2006 Hummer H2 SUT LUX...sold
2018 Polaris GEM e4
2022 Can-Am Maverick X3 XRS Turbo RR
2024 Rivian R1S Adventure
2024 GMC Sierra AT4X HD
2024 GMC Hummer EV 2X SUV
10-10-2005, 10:13 PM
Looks a lot like the new Tahoe to me. I like the new designs.
2018 Polaris GEM e4
10-10-2005, 10:18 PM
looks like they used the old 'lade wheels from the late 90's. I like the looks of the tahoe better.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
10-10-2005, 11:06 PM
hmmmm not sure what I think. I almost like the Tahoe better, which is odd as I think the current Denali looks a thousand times better than the Tahoe.
Any Escalade pics??
Thanks a ton btw.
