Old 01-18-2006, 12:44 AM
sbmike's Avatar
sbmike sbmike is offline
sbmike is off the scale
A few days ago when I started my '04 truck (22k miles on it), I happened to look in the rear view mirror and saw a small cloud of white smoke apparently coming from the exhaust pipe. It was the first time I had started it in a couple of days and it was early morning but not too cold outside. I've never had that happen before and it has not happened since. Any of you mechanic-types have any idea what the cause might be? Oil pressure is ok and oil level is good too. And, no, I had not eaten beans, boiled eggs and drank beer the night before. ;o)
04 Yellow Lux with Adv stuff like air suspension and full brush guard.
sbmike's Avatar
Old 01-18-2006, 01:07 AM
Big Z Big Z is offline
Sure it wasn't You Puff'in!
Water vapor/steam for a couple seconds!
Old 01-18-2006, 01:46 AM
sbmike's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Big Z:
Water vapor/steam for a couple seconds! </div></BLOCKQUOTE>
Hmmm... puff'n... probably not unless there's such a thing as flashback puff'n. It's been quite a while since I've done either legal puff'n or otherwise
Old 01-18-2006, 11:16 AM
ree's Avatar
ree ree is offline
I'm not the mechanic-type, but that doesn't sound good. Maybe a very small gasket leak of oil or coolant leak into the engine, not enough to cause a noticable drop in fluid levels and slow enough to only show up after sitting a couple days.
'03 pewter base H2
Old 01-18-2006, 11:38 AM
I encountered a couple of weird puffs of smoke at some Phish concerts.
I bet it was water vapor. If the readings are good and it doesn't happen again I wouldn't worry about it. Though sometimes white smoke is caused by coolant in the exhaust. Maybe you could remove the head and inspect it if it happens again later- especially the afternoon.
Otherwise, "white smoke" is typical in the morning regardless of temperature because the air is dense with moisture and cannot absorb it as it would after the sun is out. Therefore making the water vapor visible. I think it is blue or black smoke you are supposed to worry about.
Old 01-18-2006, 12:05 PM
ree's Avatar
ree ree is offline
CP,
I thought you were the medical-type not the mechanic-type.
'03 pewter base H2
Old 01-18-2006, 02:02 PM
ree's Avatar
ree ree is offline
Yeah...what CP and Phil said
'03 pewter base H2
Old 01-18-2006, 09:41 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
CP,
I thought you were the medical-type not the mechanic-type. </div></BLOCKQUOTE>
I am a Jill of all trades.
Old 01-19-2006, 01:00 AM
Shut it, Panama Red.
Old 01-19-2006, 01:05 AM
Shut it, Panama Red. </div></BLOCKQUOTE> He'll steal your woman, then rob your head
Old 01-19-2006, 02:35 AM
CP,
I am a Jill of all trades. </div></BLOCKQUOTE>
Lucky guess </div></BLOCKQUOTE>ROTFLMAO!!!
