Old 01-14-2006, 12:08 AM
Shrek_H2 Shrek_H2 is offline
Shrek_H2 is off the scale
I found this is it good quality any of you using this? Will it allow me to use 37" Tire with 20" Rim without any rubbing?
This is sold by Sandy River Enterprises...any review?
2003 Hummer H2
2000 BMW DINAN 5 (540i)
2002 HarleyDavidson V-Rod "FOR SALE"
All the great toys are on my driveway.....
2003 Hummer H2
Old 01-14-2006, 12:44 AM
rodster rodster is offline
rodster is off the scale
Check this out. link
\'05 SUT
Old 01-14-2006, 02:27 AM
wish we had a 100% definative answer on this and i cant bring up that suspensionmaxx web site, iam still rubbing cuz i havent gotten around to trimming, and im not sure that would totally eliminate the problem, my mechanic said he only tightened the torsions a little bit cuz it would be stiff, and after i pulled out of the lot it still rubbed, i think im gonna go back and tell him i dont give a fukk about the stiffness, and crank em the whole way, it is a truck anyway so who cares if it is stiff?
Old 01-14-2006, 04:31 AM
Check this out. link </div></BLOCKQUOTE>I wouldn't do it. There's been other discussions also. Just use the Find tab and poke around some.
Old 01-16-2006, 02:28 PM
Rotary Flyer Rotary Flyer is offline
Rotary Flyer is off the scale
I used a similar product on my '03. It caused the alignment to max out on the camber adjustment. That doesn't leave alot of room for future adjustments. I took it off.
Mike S
Mike S
03 Pewter H2
Old 01-21-2006, 07:11 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Don't do it! Besides, the H2 does not have the "rake" like Tahoes & suburbans. If you just lift the front it'll have a nose up look.
2003 Yellow H2 LUX (Sold)
Old 02-03-2006, 01:58 AM
Raidrz6 Raidrz6 is offline
Raidrz6 is off the scale
Just installed the same 2" leveling kit from Sandy. My 37 X 13.50 X 20's On 20 X 10 rims no longer rub. And on a flat level suface you can hardly tell the torsion keys have been changed and adjusted.
Old 02-03-2006, 03:24 AM
rocketw19's Avatar
pictures raidrz6 lets see it.
Old 02-03-2006, 04:57 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Raidrz6:
Just installed the same 2" leveling kit from Sandy. My 37 X 13.50 X 20's On 20 X 10 rims no longer rub. And on a flat level suface you can hardly tell the torsion keys have been changed and adjusted. </div></BLOCKQUOTE>Tell us about it in 6 months.
Hope it works out for you.
Old 02-03-2006, 01:07 PM
Dan Dan is offline
No way would I put those on my truck. You're going to smoke through front end parts.
That said, mine did have a rake to it so I adjusted the torsion bars to get 1" higher. Got it aligned and it sits nice and level now. No difference in ride or steering.
Anything over +1" and you're asking for trouble.
Old 02-03-2006, 07:38 PM
Check this out. link </div></BLOCKQUOTE>I wouldn't do it. There's been other discussions also. Just use the Find tab and poke around some. </div></BLOCKQUOTE>
You said poke.
Old 02-05-2006, 02:09 PM
NSANE NSANE is offline
NSANE is off the scale
Anything over +1" and you're asking for trouble. </div></BLOCKQUOTE>
True statement here! I'm new here and really don't know a lot of you guys yet. But I've been a master auto and heavy truck mech for over 30 years. I run a apparatus dept for a fire dept in MI. If this could be done without problems, I would be all over it. As I run a 2003 Jeep Rubicon with 8" of lift and 37" tires on it off-road. Beside like was stated wear on the balljoints, think of the idler arm, pitman arm, tie-rods, because of the tire size with the extra weight too. This is a dd for me and as hard as it will be, I' won't be lifting mine.
2006 H2, Black with bling!!
Old 02-06-2006, 02:13 PM
Ernie Italy is off the scale
what is the distance from the ground to fender flares in front now ?
I'm on 41.5 42".
Old 02-06-2006, 03:17 PM
after crank up the TB and the yellow bumper do not touch the lower arm, the ride is a little bit arsh and the pitman and idler goes out (but it can depend also of hard wheelin and some crash).
Now I've lowered until the yellow bumper touch the lower arm and the ride is , for me, very better...
About my post on super swamper i hope that someone understand what I mean !!!!
