02-13-2004, 11:59 AM
I have the air horns under my hood currently. I managed to get some 12" + chrome horns. I just don't know where to mount them. They won't fit under the hood and I don't want to mount them on the roof. Any suggestions?
02-17-2004, 08:02 PM
How about here....
Peyton
03 Pewter H2, Leather, Sunroof, Chrome Side Step Bars, Xenon Head Lights, Xenon DRL Lights, DRL Jumper, Chrome Letter Inserts (Rear Bumper), Tinted Windows, SMA Chrome Fuel Door, SMA Truck Cover (Thax to Jason), More to come...
Peyton
02-18-2004, 12:04 AM
peyton....
question for you... that horn you have mounted wouldnt happen to to be an airchime nathan horn...
as horn fan and owner of a nathan K-5-H i have an eye for these things... I would also add that mounting a nathan horn on your automobile is a federal offense and carries a hefty fine
BE CAREFUL!!!
02-19-2004, 05:31 PM
How did you mount it?
02-20-2004, 01:01 AM
mine is mounted on the grating of my Gobi rack...very simple mount actually. nothing special..
unaslob
ps. nathan horn or not??
03-01-2004, 02:24 PM
I have no idea who makes the horn, it is mounted on a H2 that a local shop in ft lauderdale built. It is pretty nasty.
Peyton
Peyton
01-09-2005, 09:40 PM
My air horns are not at large as your 12" trumpets, but I also was concerned about a good place to mount them. I found a useful area just behind the grill. I just fashioned an aluminum bracket to mount the horns in that area. It isn't pretty, but it does the job.
I just measured the distance between the vertical supports there and saw that it is 14" wide. You might be able to get those 12" trumpets in this area.
Also, if you can, try to get a slight downward tilt to the airhorn, to aid in water draining out, if it gets in there.
Good luck.
\"I asked my wife for a hummer, she gave me this H2.\"
03 White H2 Adventure, sunroof, Garmin GPS, Air Horns, Diablo Sport Programmer
01-13-2005, 06:32 PM
i had the two horn hella set up done and they mounted them and the compressor on the passenger side fender well, when you look down all you see is the black backs of the horns and the top of the compressor all lined up perfectly, and believe me more than loud enough, it works now with my origiinal horn, was going to put in a button to either work the origiinal horn or both of them and said hell if i am going to honk at somebody i want to honk NOW not after i flip a switch, so i get in and honk the horn the first time and i said yes now they will hear me along with seeing me, out
01-14-2005, 02:37 AM
you want the the immediate availablilty of the horns power, the real trucker feel, and control of the volume of the horn... i have one word for all of you
LANYARD!!!!
01-14-2005, 04:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by guysdad:
was going to put in a button to either work the origiinal horn or both of them and said hell if i am going to honk at somebody i want to honk NOW not after i flip a switch <HR></BLOCKQUOTE>
Absolutely, but I do like options, so I have two switches and a push button for my airhorn.
The push button sounds the airhorn, always.
One switch bridges the H2 horn button to the airhorn button, so pressing either will result in all horns going. That is the mode I normally leave the switch in. By flipping the switch off, then the horns are independent.
The second switch enables the “novelty” mode of the horn, the “turkey” mode. It is an annoying 3 note sound that is very attention getting. But I would only use it as a gag.
So, the normal position of the switches does get me the H2 horn and the airhorn “blast” of all 3 trumpets.
The switches are all mounted between the two air ducts in the top center of the dash. It is a clean looking setup.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by unaslob:
LANYARD!!!! <HR></BLOCKQUOTE>
Yup, and I agree with you there, too. I just thought that installing the tank and plumbing was a lot more work and money than I was willing to commit. But I do admire anybody who goes that route.
01-22-2005, 03:19 AM
01-27-2005, 03:13 AM
Where can I get some Nathan horns like those? You got any to spare..? MRDAVE144@aol.com
- DH22G
David
2007 Acura TL Type S
