Old 01-02-2006, 11:47 PM
MarK M's Avatar
MarK M MarK M is offline
just wondering if anyone can tell me where I can find the speed sensor wire and reverse tap in.
speed sensor for the nav and reverse tap in so that when i put it in reverse it switches to my rear cam.
I tried to do a search for a DIY on aftermarket radios but no luck.
thanks,
MarK M's Avatar
thanks,
Old 01-02-2006, 11:59 PM
x-humm x-humm is offline
x-humm is off the scale
There was a discussion in this forum about tapping into the rear view mirror for the back up camera. I know "f5fstop" came up with this suggestion.
Old 01-03-2006, 12:11 AM
WikidPete WikidPete is offline
WikidPete is off the scale
Mark,
Here is the thread that Hummer Nut was talking about. http://elcova.com/groupee/forums/a/tpc/f/4871031121/m/8...651051541#4651051541
BTW, what module did you decide to go with to retain your onstar, and etc.. ?
Old 01-03-2006, 12:20 AM
Waxing's Avatar
Waxing Waxing is offline
Waxing is off the scale
Mark a little info my Eclipse AVN535 NAV system would not turn the after market camera on automatically {it worked manually} when I switched into reverse even with the reverse wire hooked up. I then switched the camera to the matching eciplse camera and it works perfect. I switch to reverse and the camera comes right on.
Old 01-03-2006, 02:47 AM
MarK M's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Waxing:
Mark a little info my Eclipse AVN535 NAV system would not turn the after market camera on automatically {it worked manually} when I switched into reverse even with the reverse wire hooked up. I then switched the camera to the matching eciplse camera and it works perfect. I switch to reverse and the camera comes right on. </div></BLOCKQUOTE>
I went with the Pioneer and Pioneer cam. They said that if hooked up with the reverse signal it will automatically switch to the rear cam.
MarK M's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by WikidPete:
Mark,
BTW, what module did you decide to go with to retain your onstar, and etc.. ? </div></BLOCKQUOTE>
THANK YOU!!
I am using the Peripheral (Model#GMAH24)
