Old 10-02-2005, 10:18 PM
dochummer's Avatar
Ok, finished it. I connected it to the B+ terminal and it works. The only thing that doesn't work is the automatic setting. It says it doesn't have water flowing in when it's on the auto setting. I'll have to call tech support tomorrow. It works just fine manually though. Hey dick, did yours work on "automatic" when you had yours?
'03 H2
Old 10-03-2005, 04:27 AM
dochummer's Avatar
Bracket changes
'03 H2
Old 10-03-2005, 04:31 AM
dochummer's Avatar
Splice into the line on the right...put two filters/whatever on...
'03 H2
Old 10-03-2005, 04:32 AM
dochummer's Avatar
What a mess!
'03 H2
Old 10-03-2005, 04:34 AM
dochummer's Avatar
Punched through this grommet without any problems...much easier coming from the engine compartment to the inside...had to move the hood spring bracket out of the way
'03 H2
Old 10-03-2005, 04:35 AM
dochummer's Avatar
Wiring and location of button.... Not as bad as I thought it would look....
'03 H2
Old 10-03-2005, 04:36 AM
dochummer's Avatar
'03 H2
Old 10-03-2005, 04:39 AM
dochummer's Avatar
Ok, this is where I messed up... Don't do it the way it's pictured here. I tried the two posts on the top...didn't notice the second one had a 30amp fuse on it...so after blowing the first and second...finally attached it to the B+ post...the top one along the left side of the fuse box. This one has a 125amp? on it. Haven't blown that fuse yet...
Oh...anybody know where the fuse is for the left post on the top side of the fuse box? The right one was easy to see blown...but I don't know where the left one is...
'03 H2
Old 10-03-2005, 04:41 AM
dochummer's Avatar
I was too lazy to "mount" the inline fuse for the hotshot...so I just tied it down...
'03 H2
Old 10-03-2005, 04:44 AM
dochummer's Avatar
All done! I attached the ground to the convenient screw to the right of the hood latch. Took me longer than I would have liked...but this was the first time working on electrical stuff on this rig...and I was trying to keep the 16month old from crawling underneath the vehicle....kids...
Now I just have to check on the automatic setting for the hotshot. It wasn't working properly...but everything else is.
'03 H2
Old 10-03-2005, 05:15 AM
NJ H2's Avatar
NJ H2 NJ H2 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by dochummer:
It works just fine manually though. Hey dick, did yours work on "automatic" when you had yours? </div></BLOCKQUOTE>
I have exactly the same problem. I will call tech support also to figure this out. The manual says it needs to be primed by activating the regular washer fluid to fill up HotShot the first time. I did that and used half the fluid in the tank and it still didn't work!
Let me know if you find out anything.
Thanks,
Jim
Old 10-03-2005, 11:24 AM
Dick Renaud's Avatar
Dick Renaud Dick Renaud is offline
Dick Renaud is off the scale
Ok, finished it. I connected it to the B+ terminal and it works. The only thing that doesn't work is the automatic setting. It says it doesn't have water flowing in when it's on the auto setting. I'll have to call tech support tomorrow. It works just fine manually though. Hey dick, did yours work on "automatic" when you had yours? </div></BLOCKQUOTE>
The auto on mine worked fine. Can't remember the electical hook up I used. Getting old and the brain cells are going fast.
Old 10-03-2005, 03:32 PM
NJ H2's Avatar
OK, here is what I found out. Since we have dual washers (front and back) we need to install a bypass kit. Tech support is sending me 1 right away. Everything is still OK to use in Manual Setting in the mean time.
This is what they are sending me:
PDF FILE for Bypass Kit
and here is the link to the tech website:
TECH HELP FOR HOTSHOT
Old 10-03-2005, 04:35 PM
dochummer's Avatar
How much was the bypass kit +shipping? Do you think I could pick up the parts at the local auto store?
'03 H2
Old 10-03-2005, 08:45 PM
NJ H2's Avatar
How much was the bypass kit +shipping? Do you think I could pick up the parts at the local auto store? </div></BLOCKQUOTE>
Hey Doc,
No Charge for parts or shipping!
I told them someone else has the same problem and would be calling for the same parts and he said no problem.
I forgot his name but for some reason I think it's the same as mine, Jim.
Call this # 800-555-4518 hit 0 for the operator and ask them to page Tech support. I waited on hold for 20 min before I hung up and hit 0, they picked up right away after getting paged.
Jim
Old 10-03-2005, 10:50 PM
dochummer's Avatar
Awe..How did you get it for free? I spoke with the guy..he said "is this jim?" I said "no, but probably the guy I've been talking to with the same problem." He told me that I would probably need the extra parts...come to think of it...it probably wasn't Jim that I talked to. Oh well...told me the kit would cost $4.00 plus shipping. So I checked around here locally without any luck and then called the order department. Just got a fax, and it says the kit is $2.00...they're going to try and just first class it to me instead of paying for ups... Oh well....just a couple of bucks..I actually got two kits...I might install one on my wife's vehicle...
'03 H2
Old 10-04-2005, 12:07 AM
GeorgeSSSS's Avatar
GeorgeSSSS is off the scale
Guys:
I am guessing that at some point the line to the rear window nozzle passes under the vehicle with the other fore/aft piping. That means in subzero weather you must keep moving a column of heated fluid through chilled piping until you heat the piping sufficiently that it doesn't cool the fluid to the point of being ineffective in removing ice. My guess is that it would require at least two complete flushes of the rearward piping to work. I don't think the HotShot holds that much fluid. Doesn't seem very efficient to me.
I'd be curious to hear from someone who has used the rear bypass kit on an H2 in severe weather.
Let me say that I'm having the HotShot installed for use with my front washers to remove ice when I go hunting this winter. I understand it works very well in that mode.
George SSSS
Old 10-04-2005, 01:04 AM
dochummer's Avatar
The bypass actually isn't for the rear washer. It allows the hotshot pump to draw fluid directly from the reservoir. If it doesn't have the direct flow, then the pump can't pull the water through because of the "one-pump" setup. If it can't get enough flow, then the auto setting is useless...
In the end...just helps get the unit working properly for the front windshield only...
Just make sure when you/whomever installs it, you need to get the bypass kit for it to operate properly in the H2. Like NJH2 said...you should be able to get it free...otherwise $2.00.
'03 H2
Old 10-04-2005, 04:07 AM
NJ H2's Avatar
How did you get it for free? </div></BLOCKQUOTE>
Actually I just went to their website and in this video it says all units made after 01/05 come with the bypass kit and for anyone that has a kit from prior to 01/05, and need 1, can get 1 for free by contacting tech support:
CLICK STANDARD INSTALLATION VIDEO
Old 10-04-2005, 04:37 AM
dochummer's Avatar
ok, now I know who I'm calling first thing in the morning.
Just went through the tech section...did you install on the bulkhead or in the same spot I did?
'03 H2
