Old 08-15-2005, 05:09 PM
greenhummer greenhummer is offline
greenhummer is off the scale
So I am new to XM but wanted to check that it is *just* not my car...
When driving through wooded areas or even driving out in the open but with clouds, the XM reception is not good. It will continually cut out during the "wooded area" drives and occasionally cuts out when the day is pretty cloudy.
Is this normal? If so, is there a better antenna that can be had? I know that in the 2.4 GHz band that a good antenna can make a difference of 2 dB or so. Don't know the characteristics of XM.
thanks,
Greenhummer '05 H2 Lux/'00 BMW M5
thanks,
Old 08-15-2005, 05:47 PM
LasVegas LasVegas is offline
LasVegas is off the scale
Clouds should have nothing to do with it. Trees yes as they can block the signal. I have the Xmicro antenna (size of a quarter) sitting on my dash and get great reception. Sounds like you have a problem.
Jonahs
Old 08-15-2005, 05:48 PM
hi LasVegas,
Is the Xmicro antenna the factory default?
thanks,
Greenhummer
Old 08-15-2005, 06:27 PM
VTSTOMPER is off the scale
yeah XM is not what it is cracked up to be in Vermont either.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 08-15-2005, 06:34 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by greenhummer:
thanks,
Greenhummer '05 H2 Lux/'00 BMW M5 </div></BLOCKQUOTE>
Maybe it's because you need to deflate your blow-up sheep so the antenna has an unobstructed view of the sky.
Old 08-15-2005, 07:56 PM
sorry Drtyfn we cannot compare models of blow-up sheep. wifey did not allow me to get that option... :-)
Where is the antenna anyways?? Maybe my radar detector is blocking it's reception.
Greenhummer
Old 08-16-2005, 12:56 AM
hi LasVegas,
thanks,
Greenhummer </div></BLOCKQUOTE>No, it's not the factory antenna. The factory antenna is located on your roof. Here's the XMicro
Jonahs
Old 08-16-2005, 01:57 AM
hyperion78 hyperion78 is offline
hyperion78 is off the scale
if it's been crummy the past couple of days this might be the problem....stupid sun ****in everything up
http://sohowww.nascom.nasa.gov/data/realtime/eit_171/
Old 08-16-2005, 02:56 PM
Cool. Thanks guys. I may investigate getting a better antenna replacement for the roof. Perhaps GM scrimped a bit and got a lousy antenna for the roof. I'll let you know what I find.
Las Vegas - nice antenna. Was XM an add-on for you?
Greenhummer
