04-04-2005, 11:32 AM
There is a little cover in the plastic trim about shoulder high or so. You can pop that off and mount to the metal. I suspect that in the initial design they had it setup where the seatbelts were attached to the B-pillar instead of from the seat. Also, if you look the at little "ledge" and imagine that is where there would be an opening in the top to allow the seatbelt to go through and the seatbelt retractor would be housed below that.
04-04-2005, 01:41 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tower:
BTW, Jonahs,
Did you put that carpet in the utility tray in the photo? My '03 is just plastic. </div></BLOCKQUOTE>t~ That's upholstry material you can buy at PepBoys in different colors. Also get the spray on adhesive there, either removable or permanent. I used removable. Just cut to fit, spray & attach. I did all those cubby holes in my H2 including the doors. Seems like everything I thru in them rattled.
Jonahs
04-04-2005, 05:51 PM
Thank you, Paragon.
Thank you, Jonahs.
You guys are terrific!
04-04-2005, 10:22 PM
Tower, just outboard of the front seats on the B-pillar. You can mount something like a small extinguisher or a flashlight on each side there. There is also a little ledge in the plastic just above seat high on the B-pillar that cold be utilized for something. </div></BLOCKQUOTE>t~ I think this is what Paragon is talking about & looks like a good place if your equip. is not too large.
Jonahs
04-04-2005, 10:25 PM
Here's some instructions on removing the trim:
1. Remove close out panel at the top of the hinged pillar trim panel using a small flat bladed tool.
2. Remove the retaining screw.
3. Firmly grasp and gently pull to disengage the retaining clips.
4. Disconnect the lower lamp wire connector.
5. Remove the hinge pillar trim from the vehicle.
6. Inspect for broken or missing retaining clips and replace as necessary.
Jonahs
04-04-2005, 11:44 PM
I don't know, Jonahs, women are always telling me they are scared because my equipment is too large.
Sorry, it was just too good to resist.
Thanks for the help. I'll try it soon.
04-04-2005, 11:48 PM
I don't know, Jonahs, women are always telling me they are scared because my equipment is too large.  </div></BLOCKQUOTE>LOL Guess I asked for that one.
Jonahs
