Old 02-08-2004, 01:22 PM
Gromet Gromet is offline
Gromet is off the scale
Hey all,
Installed my Cobra 75 last night. I was wondering if anyone can explain to me what king of testing I can do for my connections?
I know people take a meter (I'm guessing a voltmeter) and do some readings... I have a meter but have no clue what to test or what I'm trying to see. If someone could explaing to me so I can test my install I would really appreciate it.
2003 Black - Adv/Lux Package
Hey all,
Old 02-08-2004, 02:43 PM
Find a CB shop and have them tune your CB for you. Some of the shops will even up the power for you.
Make sure that you run a ground off of your antenna base and run it back down the rubber grommet and attach it to the A-pillar. Try to make the ground line as short as possible. It needs to be done so that they can tune your antenna properly.
S&B Member since '03
Old 02-08-2004, 06:25 PM
Ok, Here is where I am at so far. I have not grounded the antenna yet. The shop I bought it from told me to come back and they would tune and ground it for me (they said the ground wire may not be necessary). I have no clue.
Old 02-08-2004, 06:26 PM
Old 02-08-2004, 06:27 PM
Old 02-08-2004, 06:28 PM
Old 02-08-2004, 06:29 PM
Old 02-08-2004, 07:54 PM
I ran a ground wire up the a pillar to the mounting bracket. and attached the ground wire from the antenna to the mounting bracket also. Should this work? Once the tune the antenna?
Old 02-08-2004, 10:28 PM
cinci cinci is offline
cinci is off the scale
Gromet,
If you off road in wooded areas you should consider some kind of spring mount for the antenna. I recently went to the snow run in Mishigan and watched several magnet mount antennas continually get nocked off due to low branches. Just a thought
Thanks,
David
Black H2
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
Old 02-08-2004, 10:37 PM
It's not a magnetic mount. Did you look at the pics. It is on a spring loaded fold down. The mount is bolted to the track in the roof.
Old 02-09-2004, 02:15 AM
Phil,
During the trip to Michigan the H2 in front of me had a medium whip similar to the one that is pictured with a magnet mount base. I had purchased a magnet mount with a metal antenna and a spring mount inadvertently. While the H2 in front of me kept getting his antenna knocked off mine didn't have any problems.
The reason that I mentioned this is that I was looking at the exact same mount as a permanent install, based on your previous posts. This made me think that with a permanent mount I would want some type of a spring mount.
The CB was a requirement for this trip since all of the Hummers were communicating over the CB.
Folding the antenna down would not have been an option due to the reduced reception range and not always having the time to stop and fold it down prior to going under the branches.
However, this may not be necessary or advantageous in other situations.
Thanks,
David
Black H2
Thanks,
David
Black 03 H2
Green 97.5 H1 Wagon
Old 02-09-2004, 07:12 PM
OK, so if the antenna is folded down and resting on my chrome crossbar it kills my reception. If I reach out and bring it an inch off the crossbar I get reception back. So I ordered a wing nut folding mount. I will tighten it so the antenna is angled back but not hitting my crossbar. that should give me reception back, and make it very har to snag... ??? no?
Old 02-09-2004, 07:30 PM
Klaus's Avatar
Klaus Klaus is offline
Those guys at the CB Shop will love trying to set the SWR with the antenna 1" from the crossbar!
Klaus
Rare 2003 H2 with UM8 Integrated Navigation Radio
Skull & Bones Member since 2003
Old 02-09-2004, 07:39 PM
I'm new to all of the CB Stuff, please explain.
