Old 08-16-2005, 12:37 PM
humv humv is offline
humv is off the scale
Here they are
Here they are
Old 08-16-2005, 08:10 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by humv:
Here they are </div></BLOCKQUOTE>
Looks good! How many turns did you take the torsion bars up to make them fit? Also, how close do they get at full lock left and right?
That tire looks quite a bit wider than the stock one.
Old 08-16-2005, 08:25 PM
That tire looks quite a bit wider than the stock one. </div></BLOCKQUOTE>
Ditto.
Old 08-16-2005, 11:17 PM
I adjusted it aprox 5 turns.From lock to lock you have aprox 1.5 inches from hitting the swaybar or the A arm. there is plenty of room. The guy that mounted the tires was surprised as well. When looking at them before they were mounted he said that they wouldn't fit.Like I said he was surprised.Oh when adjusted to 1.5 inches measure under the front fender then the back. There should be aprox 1" difference. Keep in mind 35's will fit without cranking the bars.I just wanted to get the nose up a little. Sacrificed a little in the ride department but its something I can live with.They clear even with the mud flaps on.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by timgco:
Old 08-17-2005, 01:05 AM
That tire looks quite a bit wider than the stock one. </div></BLOCKQUOTE> </div></BLOCKQUOTE>
Thanks for your answers. Now go get it muddy!
Old 08-17-2005, 10:05 AM
Thanks and good luck. I can't express enough that you need to get the front end aligned ASAP as mine was way out of wack after I cranked it.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by timgco:
Thanks for your answers. Now go get it muddy! </div></BLOCKQUOTE>
Old 08-18-2005, 02:28 AM
goose's Avatar
goose goose is offline
goose is off the scale
thats awesome! humv, what size? 35 x 12.5 mickeys?
2006 Black SUT
Old 08-18-2005, 10:12 AM
The actual size is 315/75/16 Mickey Thompson MTX.I have had BFG, Wranglers, Dunlop, Brigstone All terrains ,Mud terrains etc... but these tires are by far one of the most quiet tires I have ever owned. 35" that is.If I had to compare, I would say they compare to BFG All terrains. Not to say the others were not good tires they all have their good and bad points. I don't know how they will hold up in the long run time will tell. They ride smooth as glass! My advice is to do research. Ask questions and decide what tires work best for you. Keep in mind that these or any other 35" tire is not going to look that massive because of the size of the vehicle. With a 4" lift or so it would look more impressive. 35's as you can see fill in the wheelwells and give a stockier stance.
I'm sure as the aftermarket provdes lifts you will see some pretty triked out H3's. All it takes is time and money and I'm running short on both.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by goose:
thats awesome! humv, what size? 35 x 12.5 mickeys? </div></BLOCKQUOTE>
Old 08-18-2005, 06:20 PM
goose's Avatar
thats awesome! humv, what size? 35 x 12.5 mickeys? </div></BLOCKQUOTE> </div></BLOCKQUOTE>
I had mt mtx before you're right they are really quiet. Looks good too, anyway good luck with it.
2006 Black SUT
Old 08-18-2005, 08:52 PM
I'm sure as the aftermarket provdes lifts you will see some pretty tricked out H3's. All it takes is time and money and I'm running short on both.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by goose:
I had mt mtx before you're right they are really quiet. Looks good too, anyway good luck with it. </div></BLOCKQUOTE>Thanks! I appreciate it!
Old 08-24-2005, 05:01 PM
goose's Avatar
I had mt mtx before you're right they are really quiet. Looks good too, anyway good luck with it. </div></BLOCKQUOTE>Thanks! I appreciate it! </div></BLOCKQUOTE>
Hey Humv... how about a pic of a 35 inch spare? do you think its possible? i'm contemplating about installing a nitto terra 305/70-16 including the spare tire. just worried that it might hit the wiper.
2006 Black SUT
Old 08-24-2005, 11:49 PM
I just mounted the spare last week and it clears just fine! No need to space it out at all.It is about 3/4 inch or so from hitting the wiper.Keep in mind that my tires are on 7.5 inch rims.Having a matching spare is nice to have.When I purchased mine it was under the condition that they would fit.Don't know if your going on line to purchase or at your local store? Don't let a store tell you some BS that they can't test fit etc... I had a couple tell me that and I walked. Had one tell me without even looking at my vehicle that they wouldn't fit and that a 285 wouldn't even fit. Thats what was on it from the factory!
Good luck Goose!<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by goose:
Hey Humv... how about a pic of a 35 inch spare? do you think its possible? i'm contemplating about installing a nitto terra 305/70-16 including the spare tire. just worried that it might hit the wiper. </div></BLOCKQUOTE>
Old 08-25-2005, 04:47 AM
felsmann felsmann is offline
felsmann is off the scale
Dude aweso H3, best I've seen. I personally think 315's (35's) on H3 looks great without lift, in fact lifting it would take way the great center of gravity these H's have especially with the 35's.
Take it wheeling and show us!
Old 08-25-2005, 10:24 AM
Thank you. All I plan to do next is add some lighting. I have lifted Jeeps,Toyotas,etc...been there done that. Don't think I'll lift this one. I did put a jack under the front and simulated a 4" lift.It looked pretty darn good with the 35s. Everyone is entilted to do whatever they choose and like I said it takes money and time.I found that when you lift etc.. there are sometimes sacrifices you have to make and live with.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by felsmann:
Take it wheeling and show us! </div></BLOCKQUOTE>
Old 08-26-2005, 11:19 PM
2xtreme's Avatar
2xtreme 2xtreme is offline
2xtreme is off the scale
how do you like the mud flaps and what kind are they ?
Old 08-27-2005, 12:19 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by 2xtreme:
how do you like the mud flaps and what kind are they ? </div></BLOCKQUOTE> The fronts work just fine. I haven't put the back on yet because I'm not sure I like the way they look on the back;Personal choice. I ordered them from the dealer at a cost of $86.00 for all four and installed them myself.$86.00 was including tax.You might be able to find cheaper elsewhere. Took longer to take the tires off than to put the flaps on.
By the way , good looking H3. I like the all terrains, really looks good!
Old 09-11-2005, 01:22 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
There's a lot of reference to "35's" but will a true 35/12.50-18 M/T fit without a lift?
2003 Yellow H2 LUX (Sold)
Old 09-11-2005, 10:21 AM
The ones that I have on are as close as I would want to mount on there without a lift.I think that a true 35" tire would have to be close to what you would call a 37".A 37" tire would probably measure close to a 35" such as a BFG. That I know would not fit. I'm not a tire expert by no means,but I don't know of anyone that makes a "true" 35" tire.
Keep in mind the bigger the tire and wheels the more weight and rolling mass you have to contend with as well.
I have about 2500 miles on my tires right now and still love them!
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kacyk:
There's a lot of reference to "35's" but will a true 35/12.50-18 M/T fit without a lift? </div></BLOCKQUOTE>
Old 09-11-2005, 02:28 PM
kacyk's Avatar
The "true" measurement of these tires are 34.5 inches in diameter.
