Old 06-12-2005, 10:15 PM
How Much!! How Much!! is offline
How Much!! is off the scale
I’m thinking about getting an Xbox and DVD (I think they are one in the same) installed in my 05 H2 using head rest monitors, with wireless headphone for the kids.
It’s been a while since I looked at what is out there, so I’m looking for recommendations. Also, anybody know a good installer in the DC/VA area?
Thanks.
Thanks.
Old 06-12-2005, 10:29 PM
VTSTOMPER is off the scale
I have the two LCD's from the factory, and plan on putting the Xbox in for long hauls. I am not sure the brand that Hummer put in, but it was their *promo*. I will read the label next time I am in it!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 06-18-2005, 06:32 AM
passerby passerby is offline
passerby is off the scale
I went with a much larger project:
I installed 3 Clarion monitors (1 for the back seat)
A Clarion MSS1700 Video Switcher
1 - Front Camera
1 - Side camera
1 - Rear backup camera
1 - Play station 2
1 - DVD unit (seperate)
1 - Clarion TTX1701 TV Tuner
1 - GM Nav Unit
1 - XM Radio
1 - 12 CD Changer
The switcher allows any of the monitors to view the front camera, DVD, PS2 or the TV tuner
When I go into reverse, the GMNav unit shows the reverse camera
When I turn on my right turn signal, the GM Nav unit switches to my left side camera. A 3 second timer keeps the picture on in between turn signal blinks.
I also tapped into the GM Nav unit video so I can get video there as well with the flick of a switch. I installed a Clation controller at each monitor TSC-101.
The monitors have an AV1 and an AV2 so each monitor has a seperate RCA jack for A/V that the kids can plug something else into like a handheld game of a cam corder.
I cut into the fold down center seat in the back to install the VSS-1700 controllers and the play station.
The DVD is mounted below the Rear Radio Control, in what used to ba a little storage area.
It was a 2 week project from start to finish but it is now working. I am still tweaking it to make it more user friendly but it is coming along fine.
Let me know if you need any info on this project.
Greg
Old 06-18-2005, 11:13 AM
Wow. I love it. Who did the work for you, or was this DIY.
Old 06-18-2005, 04:40 PM
It was all myself. Some of the finer detail work like installing the monitors in the headrests, I looked on Craigslist (http://www.craigslist.com) under services and searched on installer.
I found a guy that installs alarms, TV's and such that wanted some side work for $15 an hour.
He came over and worked on the weekends installing monitors, the TV antenna, some wire pulls and helped cut in the PS2 and switcher controllers into the center console.
It was good having an expert around to help out.
Might be an idea for you.
Old 06-19-2005, 07:05 PM
Salt Lake City HUMMER Salt Lake City HUMMER is offline
Salt Lake City HUMMER is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by passerby:
1 - Front Camera
1 - Side camera
1 - Play station 2
1 - GM Nav Unit
1 - XM Radio
1 - 12 CD Changer
Greg </div></BLOCKQUOTE>
Some pictures would be nice.
Old 06-19-2005, 10:01 PM
Here are the pictures:
Old 06-19-2005, 10:02 PM
Front Camera
DVD Mounting
Old 06-19-2005, 10:03 PM
Rear Camera
Old 06-19-2005, 10:04 PM
PS2 mounting with Multimedia Controllers
Old 06-19-2005, 10:05 PM
The screens
Old 06-19-2005, 10:06 PM
The brains of it all
Old 06-19-2005, 11:20 PM
DRTYF? (the imposter) DRTYF? (the imposter) is offline
DRTYF? (the imposter) is off the scale
Cool setup man nice appointments. That being said tho...
Holy crap those cameras are GINORMOUS! I used eclipse cameras they are so tiny.
Why would you need a front camera? Arent you looking forward?
Old 06-19-2005, 11:48 PM
The front camera is for the kids. Thet get hiding behind those monitors and sometimes they like to switch to the front camera to see where we are going. They seem to watch that more than play PS2. It is also the reason I think they fight over the front seat. They like to see where they are heading.
Old 06-20-2005, 11:35 AM
AHels's Avatar
AHels AHels is offline
AHels is off the scale
Awesome setup. How much did you end up spending all in?
Some more specific information on everything would be greatly appreciated.
Looking at something similar myself, but running XP embedded as the 'brain' of it all.
Ooops! Did I step on a Jeep?
Old 06-20-2005, 06:34 PM
A couple of specs:
Switcher : Clarion MSS7100
http://www.currenttechgroup.com/products/clarion/Tech/M...ltimedia/MSS7100.zip
TV : Clarion TTX7101
http://www.currenttechgroup.com/products/clarion/Tech/M...rine_Zip/TTX7101.zip
Monitors: Clarion 7194
http://www.crutchfield.com/S-YuYkcYI...p?i=020VMA7194
Controllers: Clarion TCS101
Specs are in the above MSS7100 document
TV Antenna : Clarion ZCP-100
XM : Pioneer GEX-P910XM
http://www.logjamelectronics.com/pioneergexp910xm.html
12 CD Changer: Pioneer CDX-P1270
http://www.pricegrabber.com/search_g...asterid=406027
GM Nav Radio Video Tap : VCI-X
http://www.pac-audio.com/products/video.htm
Slimline Palystation 2
Timers (1 for turn signal for side camera (3 seconds) and 1 to leave multimedia system running for 15 minutes past time RAP turns off)
http://www.elkproducts.com/pdf/960-i...ns.pdf#search='elk%20960%20timer'
Video Amplifier: (Just one used for front GM Nav video tap)
http://www.autobarn.net/videoamplifier.html
PIE XM/CDChanger VW/PC-PIOX
http://www.myradiostore.com/vwpioXdiag.pdf#search='pie%20xm%20interface'
DVD: Fahrenheit - Outdated model - Simular model - 35
http://www.shopping.com/xGS-Farenhei...in_id-3058225~
That is the specifics on most of the items I put in. I have not totalled the overall cost yet. There was a ton of butt connectors, fuse panels (3 of them), fuses, wire (About enough to circle the globe twice) and tons of RCA cables.
Let me know if you have any other questions, be gald to help.
Greg
Old 06-21-2005, 01:54 AM
H2Finally's Avatar
Greg, excellent info!
A while back I was looking for a way to convert my turn signals to "tap --> on for 3 seconds --> auto-off" like recent Mercedes. Do you think your 3-seconds timer may work?
Thanks for your opinion!
Can BLING Get You Home?
Old 06-25-2005, 11:19 AM
AHels's Avatar
Thanks very much passerby.
Now, does anyone have experience with 'mobile' DirecTV installations?
