04-28-2004, 04:48 AM
I just came across the Kenwood DDX 7015, it is an indash touchscreen with cd/am,fm/mp3 and Sirius Satellite Radio controls & navigation ready. It measures 6.5" wide and 4" tall. Does anybody know if this will fit properly on the H2 as an in-dash replacement for the stock stereo? This is not one of those flip-ups, it would look like the stock navigation unit.
Urban-Assault Vehicle H2
04-28-2004, 04:55 AM
It opens up like the Rosen/Nevcox unit...
04-28-2004, 04:56 AM
Another pic of it closed...
09-24-2004, 11:16 AM
I just purchased the DDX7015 for my H2. The unit
will fit in the double din opening but you are
going to have some problems. If you are doing the install yourself the unit has no brackets so you will have to make some. I could not find any on the internet so I made them myself. Second, the snap ring that goes around the front of the radio pushes the unit too far out of the cavity. If you keep the trim ring you will have to cut away some of the plastic (in the h2 cavity) behind the radio to make it seat properly. If you lose it, the radio fits just about perfect. You can not mount the trim ring on the outside of the dash because the dash around factory radio is "angled in" and the
trim ring is flat. You might consider cutting into the exterior of the factory dash. I did not want to modify the factory dash at all. Once to get past those problems the biggest headache will be connecting the onstar, chimes and steering wheel contols. After alot of research here are the highlites: You have to determine which bose amp is in your H2. I have to 2004 without the premium bose sound system. In the glove box the radio code is marked "UQA". If you have the H2 with the standard bose like I do you are in luck. Another way to determine which amp you have is by unplugging the radio, if you lose the chimes - you have the standard "dumb amp". If you still have your chimes you more than likely have the premium amp.If you have premium bose sound and you are retaining the factory amp. You will lose the fade controls on any aftermarket radio you install. This kinda stinks because the DDX7015 has "dual
zone" ability so you can listen to the radio in the front speakers and listen to a dvd in the back. From the way I understand it, the premium bose only accepts two channels one left and one right. Then a seperate contol wire controls the fade on the factory radio. The standard bose sound set up is quite different. It accepts all four sound channels. There are a bunch of bus adapters on the market. Here is what I found; on the soundgate Digistar B you must install a seperate speaker under the dash to hear onstar. The Digistar B retains the fade control but I don't like the fact that you can't control the onstar through the aftermarket radio. The GMOS-02 by metra is what I was shipped by crutchfield when I purchased the radio. Don't waste your time with this. It has only two input channels left and right, which means no fade contols. The volume in the front two speakers is so loud it overpowers the rear to the point you can barely hear it. The onstar interface on the metra gmos-02 actually turns the radio off when you press the onstar button. It does not intergrate with the radio at all in my opinion. If you have the set up I have use the PAC OS2-Bose. It like the Digistar B keeps all 4 channels but it also has a phone input wire that attaches from the interface into to phone input wire on the radio. This allows you to control the volume on the onstar through the radio and mutes the sound so that the call takes priority. Most importantly, you do not have to install a seperate speaker. The PAC also keeps the radio's ability to "stay on" for 10 minutes after you remove the key from the ignition. Also you will need the PAC CM1 to keep the warning chimes and the steering wheel radio control adapter(the part # escapes me) if you need it, I will post it. One more thing, you need a DOUBLE DIN TRIM RING KIT (ABS) [UNIVERSAL FIT] to hide the gaps around the radio. Here is the link.
http://www.autotoys.com/x/catalog/DOUBLE_DIN_TRIM_RING_KIT_ABS_UNIVERSAL_FIT_p_984.h tml
You can cut and mold it yourself. It solves the exposed gaps once the radio is installed. I hope this helps. I am finishing the install this weekend.
Good Luck to anyone attempting this.
09-24-2004, 06:41 PM
WOW Gary! You sounded like Klaus' twin (and that's a compliment around here  )!! Please post photos when you post your finished installation update! Much obliged!
09-25-2004, 06:52 PM
Ok, but something does not make sense.
I have a 2003 H2 base. I looked at the codes, and mine is marked UQ7.
Now, my truck came with with single play CD/tape, which I thought was the base system. Actually, I thought all the amps/speakers were the same. The upgrades were only with the head unit (ie 6-disc).
I don't remember seeing base and/or premium bose system option...what are the differences...besides the amp??
Tom
09-27-2004, 11:43 AM
Thanks for the compliment. I finished most of the install this weekend, except for the steering wheel controls. I will finish up this weekend. I have one correction; the PAC os2-bose does mute the radio but the onstar volume is not controled through the head unit. The OS2-bose has a small dial built into the box that you rotate to set the onstar volume. Get it right because you don't want to tear the dash apart again because you set the volume too high/low.
Here are some photos. I will be installing the nav, tv, hd radio, siri in the next few months. I will keep you up to date on any problems or tricks I run into.
09-27-2004, 11:46 AM
Here is one more pic. You couldn't attach more than one at a time.
09-27-2004, 11:57 AM
Tom, the 2003 and the 2004 are different. Don't quote me but I believe the UQ7 is the premium bose set up. The amp is the difference. You are gonna lose the fade control on any aftermarket head unit replacement unless you replace the amp. I can save you some research. Contact Robert Wilson VP of Sales, Pacific Accessory Corp. www.pac-audio.com or Joe Hobart of Soundgate www.soundgate.com These are the companies that make the bus interface adapters, if these guys don't know....I doubt anyone does. I tried bose...no help. I tried hummer....no help. I even contacted helminc for the wiring diagrams for the speaker and amp set up. I was told none is available as of yet.
Hope this helps.
Garry
08-03-2005, 03:25 PM
8/3/05
I have been kinda busy but I just finished installing the TV tuner for the DDX7015 the DTC-V500. The unit is very easy to install. I mounted the antennas in the front windshield. I hid them between the liner in the roof on the glass. You have to mount the antenna in the shape of an "L"
according to the manual to get the best reception. I removed the vertical plastic sections where the small tweeter in the front of the dash is to mount the vertical section of the antenna. They are so long it is hard to find a good spot to mount it. I mounted the controller box under the center console vertically. You don't even have to bolt it down. It fits real snug. The head unit knows as soon as you plug in the TV tuner that it is there and you get a signal right away. I will post some photos in a few days. The install looks very clean with no exposed wires and the tuner pulls in the channels very nicely.
Garry
08-05-2005, 05:22 AM
Hey there Garry!
Could you tell how did you solve that fade contol and steering wheel control issues, conserning the Kenwood install. I'm not so interested about the onstar since I will not be able to use it anyways. I'm looking to get Kenwood DDX7017 on my 2006 H2, but definately want to maintain the fade and steering wheel options.
Thanks!
08-05-2005, 10:34 AM
I am not exactly sure of the amp set up
on the factory 06, I know the 03 and 04
have different set-ups. The amp is the key
to the whole thing. Check in the glove box and look for a radio code marked "UQA" if you have that code then we have the same set-up. If you have this get the PAC-OS2 Bose interface adapter. That will give you the fade controls and dual zone that the DDX7015 supports. Also you need the PAC-CM1 to get you chimes back and you will need to get the steering wheel control adapter if you want to control the radio functions with the steering wheel. The PAC-OS2 Bose has onstar support built in out of the box so if you decide to activate it later it will be ready to work. Let me know if this helps.
Garry
10-15-2005, 03:41 PM
Thanks!
I've got a bunch more questions for you though.
Like I said, I'm not interested of using the OnStar (it doesn't work here) and actually I will remocve it. I will replase the OnStar with the Nav unit that this Kenwood model does not have in it.
1. Did you have the factory Nav option before you got the Kenwood? Where did you place the Nav unit? If didn't have the nav option, where did you place the GPS antenna?
2. Can you provide me the wiring diagram of your set up. I need to have all the other functions, but not onstar. So I need to find proper PAC products and wiring diagram how to set it up.
Thanks again!
10-16-2005, 11:30 PM
I did not get the factory Nav option when
I ordered mine. I have not yet installed the
Kenwood Nav option as of yet. I may install it
next summer. I did add the Kenwood TV tuner.
I am going to place the Nav box in the space
where the onstar currently is located. I am
not sure if I am going to get a rear view mirror with the Onstar buttons and wire it myself of if I am going to install the buttons
some where else because I kept my onstar.
I will send you a wiring diagram of my set up tomorrow. I have to draw it up. I will also send you a list of what to get.
If you have not yet purchased the DDX7015 yet, you may want to look at the Kenwood DDX7017 - The menus are much better looking then the 7015s. Also, when viewing dvds you need the remote to select the menu buttons. On the DDX7017 the dvd menu buttons are fully touch screen. The 7017 has JPG & MPEG1 playback.
Garry
10-17-2005, 03:24 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Garry:
I will send you a wiring diagram of my set up tomorrow. I have to draw it up. I will also send you a shooping list of what to get.
Garry </div></BLOCKQUOTE>
Thanks! Looking forward of seeing that wiring diagram. Btw, where did you install the TV tuner antennas?
10-17-2005, 10:14 AM
Yeah, Get the PAC OS2 Bose for PAC audio. Check my previous posts on this 1st to check you amp set up.
