  #41
Old 02-28-2006, 03:27 PM
Rosetti21 Rosetti21 is offline
Rosetti21 is off the scale
Alright I will advise for the future- but I feel like such a dick now- I guess thats the whole point
Old 02-28-2006, 03:29 PM
I am gonna take a few of my own pics later and post, so you know I am not what you call a troll.
But I do feel better now thanks for shedding a bit of light-
Old 02-28-2006, 03:32 PM
Kevin B Kevin B is offline
Kevin B is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">but I feel like such a dick now- </div></BLOCKQUOTE>
That most likely has something to do with the disgusting link to the porno site .
*BTW a GRAPHIC warning would be nice*
Old 02-28-2006, 03:48 PM
Bo Bo's Avatar
Bo Bo Bo Bo is offline
Bo Bo is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Rosetti21:
Does anyone know the exact specs on the factory door height. I had a lift put on and want to make sur I pass the NJ state inspection. </div></BLOCKQUOTE>
And peopl call me a retard? You beat me.
Old 02-28-2006, 04:13 PM
guess so
Old 02-28-2006, 04:16 PM
TXSUT's Avatar
TXSUT TXSUT is offline
As for the vehicle inspection, run out into the country and get a redneck to do it. Or, find someone who knows the owner of an inpsection station and get a "hook up." Seriously, I'm not $hitting you.
Old 02-28-2006, 04:17 PM
Just a few minutes online gave me this info:
http://members.aol.com/snowman629/truck/liftlaws.htm
LIFT LAWS
04/13/99
An examination of your vehicle indicates that it has been raised more than 4 inches beyond its manufactured height. Under the provisions of N.J.A.C. 13:20-37.3, such a vehicle must undergo a geometric stability test.
These tests are being conducted by appointment only at specialty inspection locations. A comprehensive examination of the steering and suspension will be conducted. There is no charge for this inspection. Please call the location of your choice as soon as possible, since the test must be completed prior to the expiration date of your inspection sticker.
Conditions for the motor vehicles with elevated chassis heights are:
(1) Steering gear ratios and steering wheel left stop to right stop turns must be within 1/2 turn of the original manufacturers specifications.
(2) Headlights shall be mounted no lower than 22" nor more than 54" above the ground.
(3) Taillights shall be mounted no lower than 15" nor more than 72" above the ground.
(4) Off road lights must be covered while operating on public roads.
(5) License plates must be mounted no less than 12" nor more than 48" above the ground.
(6) Brake lines and hoses must be protected from excess heat and vibration. They must be mounted in a manner to prevent chafing, undue wear, stress, or unintentional disconnection.
(7) Vehicles originally equipped with bumpers must have them securely fastened, no less then 16" from the ground to the bottom of the bumper, and shall extend the full width of the vehicle.
(8) Maximum tire diameter allowed will be 38" or 6" over stock, whichever is less.
(9) All tires must be the same size. Maximum tire pressure as stated on tire is recommended. Front tires must be at least 60% of the thread width of the rear tires.
(10) Front fenders must extend over the full width of the tire thread. Rear tires that are not covered by the fender or other body parts must be equipped with metal protectors or flexible flaps that prevent dirt, debris and water from being thrown.
(11) Exposed fuel tanks must be encased. Side mounted tanks must have a protective bar to prevent rupture.
(12) Exposed exhaust system components and moving parts must be shielded.
(13) Ballast must be securely mounted.
(14) Releasing the steering wheel in a sharp turn shall result in an increase in turning radius.
(15) Spacers to increase track width are prohibited.
(16) Maximum lift heights for GVWR 4500 lbs and under... 7" above original vehicle height.
(17) Maximum lift heights for GVWR 4501 - 7500 lbs... 9" above original vehicle height.
(18) Maximum lift heights for GVWR 7501 - 10,000 lbs... 11" above original vehicle height.
(19) No blocks are allowed on the front suspension.
(20) All credentials are to be up to date.
(21) Please report to the Supervisor’s Office at least 10 minutes prior to your appointment. Lateness will result in cancellation of the scheduled appointment. Do not wait in the inspection line. Stability tests are not given in inclement weather. Please call the station if questionable.
Please Note: Vehicles that have been previously approved prior to October 1, 1998 are exempt from lift restrictions. However, all other regulations must be complied with by February 1, 1999 except limitations on tire diameter which must be complied with by October 1, 2000.
Vehicles Certified Prior to 10/1/98
All vehicles tested and approved prior to October 1, 1998 will have until October 1, 2000 to comply with the tire diameter requirements. While all vehicles approved prior to October 1, 1998 will be exempt from the maximum lift requirements, once the vehicle is retrofitted to comply with the new tire regulations, a new stability test will be required.
Effective October 1, 2000, maximum tire diameter will be no more than six (6) inches larger than the stock tire available from the manufacturer ( for that model and model year ) or thirty-eight inch diameter, whichever is LESS. </div></BLOCKQUOTE>
Old 02-28-2006, 04:19 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by TXSUT:
As for the vehicle inspection, run out into the country and get a redneck to do it. Or, find someone who knows the owner of an inpsection station and get a "hook up." Seriously, I'm not $hitting you. </div></BLOCKQUOTE>
Very true. Used to know the owner of the shop that did inspections for us on our company vehicles in MO. He did several inspections for lifted trucks we had that would not pass due to height but we were good to go.
Old 02-28-2006, 06:12 PM
8,500 posts for you paradick, wow you have no life </div></BLOCKQUOTE>
What a looser. Only 8,500 posts </div></BLOCKQUOTE>X2brazillion!
Old 02-28-2006, 06:37 PM
What a looser. Only 8,500 posts </div></BLOCKQUOTE>How the hell did you get so far ahead of me?
Old 02-28-2006, 07:16 PM
ZigsRig ZigsRig is offline
ZigsRig is off the scale
<font size=20> <marquee>PAD</marquee></font>
www.ZigsRig.com
Old 02-28-2006, 09:34 PM
HummBob's Avatar
HummBob HummBob is offline
[quote]Originally posted by Rosetti21:
Does anyone know the exact specs on the factory door height.QUOTE]
Nope
BLACK \'04 H2 LUX
BLACK \'07 ESCALADE
Old 02-28-2006, 09:37 PM
What a looser. Only 8,500 posts </div></BLOCKQUOTE>X2brazillion! </div></BLOCKQUOTE>
12,700 post for you Ken, wow you have no life </div></BLOCKQUOTE>So.
Old 02-28-2006, 10:12 PM
Damn I forgot what the topic was after reading through Ken's 12,755 posts
Old 02-28-2006, 10:15 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by DDWH:
Damn I forgot what the topic was after reading through Ken's 12,755 posts </div></BLOCKQUOTE>Did your brain just fall out of your head?
Old 02-28-2006, 10:36 PM
Spike Spike is offline
originally posted by Kevin B,
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">*BTW a GRAPHIC warning would be nice* </div></BLOCKQUOTE>
That would ruin the effect. The whole idea of "the meat spin" is to shock and surprise! It's a f$ckin Elcova Classic!!!
