Old 11-18-2005, 11:46 AM
Huck BB62's Avatar
We have the factory rock sliders. After being in the mud without flaps, it's MISERABLE. Are there any mudflaps that work with the rock sliders?
Huck BB62's Avatar
Old 11-18-2005, 01:23 PM
you can use the factory ones... even though it sais you cannot! There were earlier posts about this and other have done it.
Disclaimer: I have not tried it yet, so this is info from another post, not my experience.
Also, some have broken off their mudflaps due to mud/ rocks.
Old 11-18-2005, 04:05 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
Yeah you can use the factory OEM ones they work just fine. I put a picture out there somewhere. Make Find your friend.
Old 11-19-2005, 01:14 AM
tmiller tmiller is offline
tmiller is off the scale
I think they are trying to tell you if you use your rock bars theres a good chance you will tear off the mudflaps. Yes they fit. I also put my tube steps back on under the rock guards with custom made brackets in almost the same stock location, 4 bolts and they are off.
Old 11-19-2005, 01:30 AM
I have both. I have not torn one or ripped it off, but I have bent them pretty good.
They are made of a hard molded plastic, so there is some give, not much though.
In real serious mud, they do not help. See black rock desert in the Local Events and Activities.
But, for keeping the daily splashing from making rooster tails down the side of your truck, they work great.
Old 11-19-2005, 01:32 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tmiller:
I think they are trying to tell you if you use your rock bars theres a good chance you will tear off the mudflaps. Yes they fit. I also put my tube steps back on under the rock guards with custom made brackets in almost the same stock location, 4 bolts and they are off. </div></BLOCKQUOTE>
Please speak about those custom made brackets for your side steps....I was thinking of having some fabbed.
Is that set up like what the H2's have?
tmiller, can you post some pics as to how you did this. My sig other has the H3 and would like the option of having both.
Old 11-19-2005, 02:01 AM
H3 Hummer's Avatar
I have a video where I smooshed them very good went on three wheels and they popped back in place just fine. I don't think it is an issue.
Old 11-19-2005, 02:14 AM
Im new to puting pics. on the computer. Maybe my kid can do it. Just take the mounting bracket and cut the end off that mounts to the frame and redrill the holes in the tube step that mounts the bracket to tilt it up to the rock bar piece that has 2 holes in it . Drill the bracket to line up with one of the holes in the rock bar and bolt it. That is for the front bracket. The back bracket you do the same but add an aprox. 3 inch piece of flat bar to tie them in. (because I mounted it by the flat step area) and at the very ends use a threaded bar and drill through both bars and tie together. To do the first side it took me about an hour and a half to figure it out then the otherside went much easer in about an hour. and it looks factory.
Old 11-19-2005, 02:23 AM
Im new to puting pics. on the computer. Maybe my kid can do it. Just take the mounting bracket and cut the end off that mounts to the frame and redrill the holes in the tube step that mounts the bracket to tilt it up to the rock bar piece that has 2 holes in it . Drill the bracket to line up with one of the holes in the rock bar and bolt it. That is for the front bracket. The back bracket you do the same but add an aprox. 3 inch piece of flat bar to tie them in. (because I mounted it by the flat step area) and at the very ends use a threaded bar and drill through both bars and tie together. To do the first side it took me about an hour and a half to figure it out then the otherside went much easer in about an hour. and it looks factory. </div></BLOCKQUOTE>
OMG Please Please please.......
Sounds good, but I have to see it. Completed.
See this post on how to post pics
THANK YOU!
Old 11-19-2005, 11:47 PM
How do you post pictures on here
Old 11-20-2005, 12:00 AM
OK click the reply button.
When the window opens select "add attachment"
Select the Browse Buttonand find your photo on the computer.
When you have found your photo, select it a hit Open.
Then hit post now!
Old 11-20-2005, 12:52 AM
Thanks .... now it says its too big. My kid is trying to down size. Im learning
Old 11-20-2005, 12:56 AM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
tmiller, take a new picture with less resolution and it should be smaller and ok to post. I don't know why but it works for me.(my kid figured it out)
WWW.BCBI.COM
Old 11-20-2005, 12:57 AM
No worries, mine had to teach me...
just open the pic in microsoft paint and change the size by a percentage, then resave it.
Old 11-20-2005, 12:51 PM
Here are the pics. I hope this works.
Old 11-20-2005, 12:54 PM
Another pic
Old 11-20-2005, 12:55 PM
and another
Old 11-20-2005, 12:56 PM
pics.
