11-28-2005, 10:05 PM
141519.6 Kbps - You 141519.6 kbps
Boy I should start my own ISP... Don't mind me, just entertaining myself. What has me baffled is I have my connection stretched to the max right now and it keeps getting higher.
11-28-2005, 10:07 PM
I just got 141519.7 Kbps
11-28-2005, 10:16 PM
11-28-2005, 10:34 PM
I just got 141519.7 Kbps </div></BLOCKQUOTE>
Weeeeeeeee!
11-28-2005, 10:35 PM
That thing is bogus. I went from 278 to 17000.  Pretty impressive for a T1 (1500 kbps max).
Try the one at 2wire. Link
I'll go climb back under my techie rock now.
11-28-2005, 10:43 PM
11-28-2005, 10:45 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Sewie:
I'll go climb back under my techie rock now.  </div></BLOCKQUOTE>
I got 7.16Mbps with yours and then 1.5Mbps on the new link I posted. Me thinks they all bring the suck.
11-28-2005, 10:46 PM
It's probably because your computer cached the information...I hit 31000....but both times I did it properly, it came out around 1440kbs
'03 H2
11-28-2005, 10:48 PM
1.1mbs on drty's second link...both tries...
'03 H2
11-28-2005, 10:55 PM
Ok, whiners(  ), try this one:
http://www.bandwidthplace.com/speedtest/ </div></BLOCKQUOTE>
Meh....926.6 kilobits per second
Easiest way to figure out how much bw you have is to divide the number the company says they give you. 4mb = 400k cap, 10mb = 1000k cap, 512k = 50k cap, etc..
Unless you can find a data center very close to you for a test you will likely get numbers all over the board. Caching really isn't a concern cause you are sending and receiving packets just to get a generalization of speed. I honestly don't think any of them are ever very accurate. Best way is to do the math yourself.
11-28-2005, 11:01 PM
4.9 megabits per second.
11-28-2005, 11:03 PM
now 2.7
11-28-2005, 11:07 PM
http://www.wugnet.com/myspeed/speedtest.asp
this one says I'm at 6.3Mbps
they're all wacked. I am paying for a 5Mbps feed but that's download the upload is usually capped to something below T1 speeds or 1.5Mbps
11-28-2005, 11:13 PM
11-28-2005, 11:20 PM
512.10Kbps
11-28-2005, 11:34 PM
1.21 Gigawatts
11-28-2005, 11:51 PM
5224.1 Kbps
11-29-2005, 12:44 AM
Warp 9.75
11-29-2005, 01:10 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CslRkH2:
1.21 Gigawatts </div></BLOCKQUOTE>
