Old 12-19-2005, 07:48 PM
HummerB HummerB is offline
HummerB is off the scale
Anyone have some suggestions on how to properly remove the center console. I am planning on installing the empty light switches to wire some off road lights to the BG.
Birch wht (black accents/anti-bling), auto lux, oem flat side steps, oem brush guard, silver crossbars, SMA exhaust, PIAA 520 offroad lights, Valentine One.
Old 12-19-2005, 08:08 PM
fourfourto's Avatar
Stick your 2 fingers in the sockets and pull on upward angle than work slowly around.Easyer the second time around.
Old 12-19-2005, 08:10 PM
First Hummer is off the scale
very easy dude,first make sure you disconect the negative termunal to battery to avoid shorts.Place you 2 fingers in the power slots at bottom of console and pull out ,should come out pretty easy.Then just pull around the console to remove other clips.The upper vents will come with it so dont be suprised.You will have to disconnect some clips on back of console to make room to work.GOOD LUCK.
Old 12-19-2005, 08:11 PM
crop000s crop000s is offline
crop000s is off the scale
It pulls out. You can get it out far enough to place the switches in dash without removing any wiring. I removed the switch plugs and installed PIAA swicthes in that location.
Dallas Stars Green, adventure package, 5 speed, sunroof, xm, mp3,grill guard, tranny guard, rocker guard, rubber mats, GOBI rack, PIAA lights.
Old 12-19-2005, 09:16 PM
Crisco Crisco is offline
Crisco is off the scale
I have some detailed pictures of a head unit replacement at http://www.rausite.com/hummerh3.htm.
Old 12-19-2005, 09:29 PM
hey "FIRST HUMMER":
How did you wire the PIAA's that is the same setup i am planning on running. Curious of how to breach the firewall etc. Can i locate the wires in the fuse box??
Old 12-19-2005, 10:59 PM
WPBGUY WPBGUY is offline
WPBGUY is off the scale
Yes, the finger method works best.
Can you believe the official instructions from GM says to pry it out using screwdrivers? OMG! I guess they don't wat anyone getting electricuted, sticking body parts into the sockets!
