Old 12-04-2005, 02:10 PM
VTSTOMPER is off the scale
who has done it, and what should one go with? I am thinking about that as a mod when I do my tierods, and other hardware goodies.
I have seen threads talking about an elocker, and that is probably the only why to fly. Let me know your thoughts!
FYI: this is a wish list I am putting together!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 12-04-2005, 02:17 PM
VernB VernB is offline
VernB is off the scale
I went with Eaton front locker. from http://www.trailduty.com/
Old 12-04-2005, 02:20 PM
this is the one? Looks pretty kewl! I just like the idea of lockers! I have found them to help, and save time when your in the giggle weeds!
http://www.trailduty.com/products/eaton/index.html
Old 12-04-2005, 03:21 PM
tomp's Avatar
tomp tomp is offline
I am considering adding the Eaton as well. I will probably install some sort of safeguard switch setup to keep the e-locker from being engaged accidentally at high speeds.
Old 12-04-2005, 03:33 PM
isn't there a button you push to enguage it?? would you add another switch of some type?
Old 12-04-2005, 05:23 PM
isn't there a button you push to enguage it?? would you add another switch of some type? </div></BLOCKQUOTE>
PM PhilD. He has the Eaton and the upgrade kit you are looking into. I think he has a complete wirte up on his site too.
Old 12-04-2005, 05:45 PM
MWAHAHA!
I just pmed PhilD, I will have to send him another.
{edit I am a dumbass} what does the H2 have for the front now? Open dif, limited slip, or posi?
Old 12-04-2005, 07:32 PM
tomp's Avatar
I would also consider maybe a keyed swtiched for safety.
What is this "upgrade kit" for ?
Old 12-05-2005, 04:46 AM
Can you break a CV?
Old 12-05-2005, 07:53 PM
HGW HGW is offline
HGW is off the scale
Has anyone considered the ARB air locker?
I was just "sold" on it by ARB at the PRI show.
Before I jump to start selling these things, I would like some off roaders opinions.
Old 12-05-2005, 08:14 PM
tomp's Avatar
HGW, what would be the advantage of the ARB over the Eaton? A negative would be that you'd have to add another air compressor right?
Old 05-29-2006, 12:13 PM
31_bandits's Avatar
31_bandits 31_bandits is offline
31_bandits is on a distinguished road
Default Re: Front locker.
I am interested in an Eaton locker for my H2.
I read the links above: http://www.trailduty.com/products/eaton/index.html
and http://www.*******club.com/tech/eaton.html
And some questions come to mind. The article implies that the locker can't be installed with an auto-off idiot-proof feature like the rear-locker. That's not necessarily bad - you could build a cage in front of the switch to prevent something heinous. But its not ideal, i guess.
I'm not the worlds most experienced offroader but i'm learning. How often do those with a front locker benefit? Does the presence of the device when not in use add strain to the truck? Will it void my warranty, or part of it? I have a feeling that offroading would, in some roundabout way, wind up voiding warranty in any case. "well, that happened because of the time you ..."
And last, is it probably that my tires would become the limiting factor before need for a front locker? (i have the factory A/Ts)
She makes me wanna feel
She makes me wanna try
She makes me wanna pull a star from the sky
Old 05-29-2006, 03:25 PM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
I definitely want a front locker. Anyone know a ballpark installation charge?
Old 05-29-2006, 03:57 PM
Auggie Mathis Auggie Mathis is offline
Auggie Mathis is off the scale
I put in the eaton locker. The best price I found was at trailduty.My old ARB lockers would corrode and not work when I needed them
Auggie
Old 05-29-2006, 04:44 PM
About 1K installed with tax. That was buying it from Phil and having 4WP do the installation.
I plan on doing with WInch bumper first, than the locker.
Phil or others, where did you mount your switch? Pic?
Old 05-29-2006, 05:09 PM
tomp's Avatar
More than once I have had my vehicle in for service & got it ack with switches turned on. Since these places need to move the vehicle, I would strongly consider a seondary switch in the circuit that would prevent them from turning it on without a key.
Old 05-30-2006, 04:04 AM
Here is Phil's- under the tow/haul button.
http://www.elcovaforums.com/forums/showthread.php?t=13298&highlight=front+locker+butt on
